Re: mopar with a glide
[Re: wyldebill]
#1803965
04/15/15 03:36 AM
04/15/15 03:36 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
It isn't, in fact, some guys cut it off completely. My stock PG case was notched to clear it, no problems in 10 years of racing with it like that.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: wyldebill]
#1804034
04/15/15 10:32 AM
04/15/15 10:32 AM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
I have a glide and it bolts to the mid-plate...so does the starter.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: wyldebill]
#1805645
04/17/15 02:56 PM
04/17/15 02:56 PM
Posts: 279 Chicago land, IL
dafixr
Chicago land, IL
We just did this conversion. This is what I came up with. Big Block Mopar- 1/4" mid plate; JW bell-housing and case; JW flex plate; JW crank spacer .250 thick. With the following I had .125/.180 clearance to move convertor to flex plate. No starter shims needed also. Pull dowel pins out of block and get longer ones and taper edges makes for easier install. I tried 3 different crank spacers had trans in and out 4 times this came out to be the best combo. Check JW web site for parts and numbers also you check Coan web site for parts too. Can get all from JEGS with free shipping. Good Luck
Also we used a Power Master starter #9513 and Neal Chance 2 pc.convertor
