Carter 4327s Edited SECONDARY venturi cluster question #1802708
04/13/15 09:45 PM
04/13/15 09:45 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
Should this have some plumbing coming out the bottom like newer Edelbrocks or should it be this way? It came off this way. Thanks pete
oops. Cant add pics from my cell? Will upload soon. Basically no piping coming out from bottom holes.
Re: Carter 4327s primary venturi cluster question [Re: p d'ro] #1802751
04/13/15 10:24 PM
04/13/15 10:24 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
has to have an emulsion tube and an idle jet tube.
Re: Carter 4327s primary venturi cluster question [Re: p d'ro] #1802787
04/13/15 10:42 PM
04/13/15 10:42 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
So this is not good I assume. Maybe one tube out of large hole called acceleration tube? Neither had one??
Re: Carter 4327s primary venturi cluster question [Re: p d'ro] #1802871
04/13/15 11:39 PM
04/13/15 11:39 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i don't see a secondary discharge nozzle,...? or a secondary well tube,...?
Re: Carter 4327s primary venturi cluster question [Re: p d'ro] #1802919
04/14/15 12:08 AM
04/14/15 12:08 AM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
This is my first old afb so I didnt realize any issue when i took it apart. Everything was crusted but I dont know if someone previously modified it. If it is wrong i dont think there is a source for replacements. Bummer.
Re: Carter 4327s primary venturi cluster question [Re: p d'ro] #1803149
04/14/15 12:19 PM
04/14/15 12:19 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
see if you can find a "parts" edelbrock 1405 and use the secondary clusters out of it.
Re: Carter 4327s primary venturi cluster question [Re: lewtot184] #1803168
04/14/15 12:54 PM
04/14/15 12:54 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
Wow, thanks for the tip. I did not know they were interchangeable. I have a 750 performer on my car now. I wonder if that would work?
Re: Carter 4327s primary venturi cluster question [Re: p d'ro] #1803249
04/14/15 02:15 PM
04/14/15 02:15 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the clusters are the brains. the carb body's on the majority of those afb's are the same. chrysler had a couple of versions that were a little different. what you have is of the more conventional style. anyhow, the 750 clusters should screw in and work. they're basically the same carb. the 750's are jetted quit a bit richer than a stock carb but that's easy to deal with. the only hitch would be the air bleed sizes but i don't think thats a major problem.
Re: Carter 4327s primary venturi cluster question [Re: p d'ro] #1803279
04/14/15 02:52 PM
04/14/15 02:52 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
Thanks. I will give it a shot. Don't really have another choice. I have an A/F meter so I will know if it isn't right. Just put an ad in engines want ad section for junk Eddy!
Re: Carter 4327s primary venturi cluster question [Re: p d'ro] #1803811
04/15/15 12:07 AM
04/15/15 12:07 AM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
I was told by the seller of my rebuild kit that some AFB secondary venturis did not have down tubes. Has anyone else seen this?
Re: Carter 4327s primary venturi cluster question [Re: p d'ro] #1803903
04/15/15 01:36 AM
04/15/15 01:36 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I'd have to look at my stash of carbs, but AFBs came in two styles. Those with a weighted air valve in the secondary and those without. In my experience RB motors had carbs without the air valve. The secondary clusters were completely different on the two styles.
Re: Carter 4327s primary venturi cluster question [Re: p d'ro] #1803984
04/15/15 06:49 AM
04/15/15 06:49 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Very possible, I'd try the carb first before swapping parts about. Carter made several hundred different AFB's for OEM applications over time.
"I think its got a hemi"
Re: Carter 4327s primary venturi cluster question [Re: p d'ro] #1804045
04/15/15 10:56 AM
04/15/15 10:56 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i don't know how they could draw fuel out of the well without a tube. pm 62maxwagon for some details. he has parts and refurbishes carbs. he'll probably know.
Re: Carter 4327s primary venturi cluster question [Re: lewtot184] #1804083
04/15/15 12:28 PM
04/15/15 12:28 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
i don't know how they could draw fuel out of the well without a tube. .
Tube is mostly for emulsion since it has holes in the sides, the vacuum from the booster venturi would have no problem sucking the fuel up from the well.
Re: Carter 4327s primary venturi cluster question [Re: gdonovan] #1804095
04/15/15 12:41 PM
04/15/15 12:41 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
how does the carb siphon fuel if nothings in the fuel supply? can you sip a coke thru a straw without the straw in the coke? maybe i'm missing something here and somebodys going to have to draw me a picture?
Re: Carter 4327s primary venturi cluster question [Re: p d'ro] #1804100
04/15/15 12:47 PM
04/15/15 12:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The tube is the hole in the casting. The brass tubes you think are siphoning fuel are not there for that purpose. They are there to mix air with the fuel (emulsion). To use your Coke analogy it's like sipping Coke with a hole in your straw.
Don't be the exception.
Re: Carter 4327s primary venturi cluster question [Re: p d'ro] #1804130
04/15/15 01:23 PM
04/15/15 01:23 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
Gotcha, so do you think this carb came stock without them? Obviously there is no way I will get the original Carter diagram of the 4327s..
If anyone has a junk 1967 Carter 4326 or 4327 AFB sitting around that they would split and check for me, I will find a monk that will grant you total consciousness on your deathbed...
Re: Carter 4327s primary venturi cluster question [Re: p d'ro] #1804139
04/15/15 01:37 PM
04/15/15 01:37 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I forget, it has been almost 30 years since I fooled with an old AFB, I run the E brock version these days. Someone with the FSM for your year/model might be able to look at the carb section and answer.
Re: Carter 4327s primary venturi cluster question [Re: p d'ro] #1804176
04/15/15 02:20 PM
04/15/15 02:20 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
I wouldn't , you'll be potentially transferring the reason that particular carb is a POS to the replacement carb.
Re: Carter 4327s primary venturi cluster question [Re: JohnRR] #1804368
04/15/15 07:09 PM
04/15/15 07:09 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
