Page 2 of 3 1 2 3
Re: 700 N/A vs 700 Blown [Re: hudsonhornet7x] #1801652
04/12/15 01:22 PM
04/12/15 01:22 PM
USA
hudsonhornet7x Offline OP
USA
Right now we have a new 6.4 short block, we want to change at least the rods and pistons to forged. I understand the crank is a nice piece from the factory.
Fully ported eagle heads, flow 340ish
Got a chance to use a magnuson supercharger- if we can afford it that is!
Anyone see a problem yet?
Re: 700 N/A vs 700 Blown [Re: dizuster] #1801795
04/12/15 05:04 PM
04/12/15 05:04 PM
Originally Posted By dizuster
Originally Posted By Blusmbl
It can take 100+ extra horsepower to drive a supercharger even on a mild 600-700hp street engine, so the entire rotating assembly is going to see additional stress from the cylinder pressures over an n/a motor. However, for the same displacement the n/a motor would have to spin at higher rpm, which requires more expensive valvetrain components.
Cranks see maximum stress near TDC. Because boosted motors run less timing, the cranks actually see a lot less stress vs. a N/A motor.
Let see, the boosted motor has forced a lot more air and fuel into the cylinders and that ignites and makes a lot more power than a N/A combination would so how can that posiibly make less stress? BTW, I have made motor with Roots super charger that made peak HP (496 C.I.street hemi on pump gas 927HP) at 7300 on pump gas and N/A motors on race gas that made peak 730 HP( 471 C.I. wedge) at 7300 RPM. Same RPM for peak HP, which one has the most stress on the rotating components in your mind? Insert whistling Emotioncon here with smiley face after it. On your deal with the turbo where it does not drive the turbo off of the crank and it does not gain boost directly proportionally to RPM, depending on the throttle and gear it is in, it will not have the same stress per RPM as a supercharge motor will with all other things being the same. HP makes stress, less is less.
Re: 700 N/A vs 700 Blown [Re: hudsonhornet7x] #1801911
04/12/15 08:36 PM
04/12/15 08:36 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Cab we're talking 700hp NA to 700hp boosted right? Not 927hp boosted, vs. 730hp N/A. I think it's fairly obvious that more power means more stress, but you're trying to compare apples and oranges to make a point.
What about 730hp N/A vs. 730hp Boosted both at 7300rpm. Which one has less rotating assy stress? I bet the N/A motor has 35 degree's of timing in it, and I bet the boosted motor has 25 degree's in it.
Less peak pressure but holding it over a longer period of rotation will make more power with less stress on the parts.
If I shove a bunch more air/fuel in the cylinder, and light it off late (low timing), it can keep burning nice and long at low pressure to keep pushing on the crank as it rotates. N/A has to light off what little air/fuel it has early (lots of timing), and that tries to push the crank out the bottom of the block from the pressure spike.
Same reason in principal why parts get damaged when the motor detonates. That early pressure spike near TDC is HARD on parts.
Below is a really good graph. The red line is a 11:1 4 banger motor at 45 degree's of timing which made 156 ft/lbs. The blue line is the same motor with 15 PSI of boost, and only 25 degree's of timing but it made 213ft/lbs. Notice that the peak pressure is the same on both. (Meaning in this particular case they would have similar crank stress). This is a good example of what I was talking about above... that the boosted motors can hold the pressure on the crank longer/later to make power. No additional peak pressures (stress) at TDC... but picked up 35% in torque.
However if we were just looking to make the same 156ft/lbs you can imagine with lower timing how low the peak would be on the boosted motor to make the same power. This is what I'm talking about why boosted motors are less stressful on parts then they're NA counterparts at the same power level.
BTW... the link below is a good read if anyone wants to dive into the topic further.
Ottoboost_2 by wright2305, on Flickr
https://www.physicsforums.com/threads/high-compression-turbocharged-engines.646362/
Re: 700 N/A vs 700 Blown [Re: hudsonhornet7x] #1801970
04/12/15 09:43 PM
04/12/15 09:43 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Doesn't the cylinder pressure required to make the power equal the same in the end? Kinda a wash IMO? Difference is one crank has more leverage on the crank snout,blower pulley, than the other. I like turboes more betta...
Mopar to the bone!!!
Re: 700 N/A vs 700 Blown [Re: hudsonhornet7x] #1802296
04/13/15 11:44 AM
04/13/15 11:44 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The blower motor can make the power at a lower engine speed which is the key here. To make the 700hp N/A will usually take more RPM. Stress/load goes up much faster with increased RPM than it does with increased HP. So the stress/load may be the same at the same HP and RPM between the 2, but additional RPM adds additional stress and load.
Master, again and still
Re: 700 N/A vs 700 Blown [Re: WO23Coronet] #1802339
04/13/15 01:05 PM
04/13/15 01:05 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Originally Posted By WO23Coronet
On paper they should be equally as quick, but realistically the blower motor would get there easier and would be a lot more fun to drive. I also think the blower motor would be quicker with a not so ideal set up (who ever has a perfectly dialed in set up). I'd go forced induction
boosted would give you a drivable/usable car, whereas 700N/A would give you a super high compression, big bumpy cam not streetable car that would require high octane, expensive high stall and most likely need steep gears to work.
Coming soon!!!!
Re: 700 N/A vs 700 Blown [Re: dizuster] #1802482
04/13/15 04:21 PM
04/13/15 04:21 PM
Let me try to set this up so it does not come off as arguing for argument sakes, I'm of the opinion that any time you use a power adder of any sort your adding stress into the motor by artifiscially (SP?) inducing more power than the motor will make normally. As far as HP per C.I. you can make a very small C.I. motor make a lot of power with enough compression and RPM, you can make a much larger C.I. motor make the same HP at a much lower RPM with a lot less strees on the components due to the lower RPM. As far as adding boost and reducing timing your reducing the timing the stay out of detonation, the inside combustion chamber temps. are much higher with the added pressure of the boost and will detonate a lot sooner than having the pressures less, hence you retard the timing to stop detonation. The blown Hemi mtor I referrenced like 33 degrees total timing with 7 lbs of boost at 12 % underdriven on CA pump swill, I had tried 28 to 35 degrees and it like 33. We switched the fuel to C16 and reverse the pulleys so the motor would overdrive the blower 13%, I reset the timing to 25 degrees and made a pull. The motor made peak HP (1027 HP) at 6500 RPM with that timing and 12lbs of boost, but is was on the edge of detonation and stop gaining power at 6500 work I reset the timing up 2 derees to 27 and the motor started into detonation at 6200 RPM so we stop the pulls at that time. Maximum effeincy can be tuned for any combination, large C.I. and slow RPM will make a lot more torque than a smaller motor making the same HP at a higher RPM, especially with boost shruggy Is that chart you link to for a small europen deisel motor, Otto cycle? If so you and I both know that diesel motors that self ignite have to have stronger cranks, rods, pistons and blocks to make them live at the same power levels as a gas motor makes, correct? If it isn't for a deisel motor forgive me for seeing and thinking of Dr. Otto Deisel, or Dr. Deisel Otto (which ever his name was confused) the inventor of diesel motors and theory. My last pump gas street stroker motor in my Duster made 727 HP at 6700 RPM and 540 ft. lbs at 3500 RPM and had 735 FT lbs at 4500 RPM. It was a blast to drive and did require some maintenance on the valve springs do to using a moderate solid roller cam on the street, if I had added a blower to a smaller C.I. motor to make the same HP I'm sure it would have required more maintenance and better parts to live at that power level work Lots of ways out there to have fun up
Re: 700 N/A vs 700 Blown [Re: hudsonhornet7x] #1802542
04/13/15 06:19 PM
04/13/15 06:19 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Rudolf Diesel (who invented the diesel) worked at Deutz as did Nikolaus Otto (who gets the credit for the current 4 stroke engines).
2011 Drag Pak Challenger
Re: 700 N/A vs 700 Blown [Re: rickseeman] #1802997
04/14/15 02:00 AM
04/14/15 02:00 AM
Thanks for clearing that up upSeems like there are a lot of German inventors in the automobile and internal combustion motor designing and history work
Re: 700 N/A vs 700 Blown [Re: Mr.Yuck] #1803188
04/14/15 01:17 PM
04/14/15 01:17 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Nah, 12.1.1 comp.,5000 plus vert, .680-.660 solid roller and 4.11 gears here and it drives like a kitten till you stab the happy pedal then it`s a tiger. Great torque off idle and pulls past 7 grand with ease and I drive it more than just to car shows. N/A all the way for me till something changes between my ears and eyes.
Re: 700 N/A vs 700 Blown [Re: Thumperdart] #1803319
04/14/15 03:36 PM
04/14/15 03:36 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
haha you are not going to take a 700hp on a 150 mile road trip you can however do it w/ a 700hp boosted motor. It is what it is.
Re: 700 N/A vs 700 Blown [Re: Mr.Yuck] #1803334
04/14/15 04:09 PM
04/14/15 04:09 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
NEVER ASSume anything and I have driven it that far for a local movie shoot in the middle of bfe..........
Re: 700 N/A vs 700 Blown [Re: Thumperdart] #1803387
04/14/15 05:34 PM
04/14/15 05:34 PM
The State of Hockey
2qik4u Offline
2qik4u  Offline
The State of Hockey
I believe the naturally aspirated 700HP will vary more as weather conditions change and the blown 700HP would be a better power plant on the street.
Re: 700 N/A vs 700 Blown [Re: hudsonhornet7x] #1803393
04/14/15 05:38 PM
04/14/15 05:38 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
One downside the blown combo will have is the increased weight on the front end. I'd still choose the blown engine if its a street driven car.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: 700 N/A vs 700 Blown [Re: Mr.Yuck] #1803407
04/14/15 05:50 PM
04/14/15 05:50 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
my old big block made over 700 and drove 400 miles a day at Drag Week without a single problem and it was like 5 years old at that point
and my current Hemi is around 600+ and it very mild and I already did Drag Week with it also
Re: 700 N/A vs 700 Blown [Re: hudsonhornet7x] #1803628
04/14/15 10:04 PM
04/14/15 10:04 PM
jersey
Spaceman Spiff Offline
jersey
If forced induction was that hard on parts, the OE's wouldn't have been doping it since the 30's.
You think Gm is going to put out a 650 supercharged cadillac if they think it will be hard on parts and come back for warranty work?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: 700 N/A vs 700 Blown [Re: hudsonhornet7x] #1804414
04/15/15 08:38 PM
04/15/15 08:38 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
The OEM's put in the correct parts to survive supercharged applications. An LS9 chevy has forged pistons, while the n/a LS7, with a 600 rpm higher rev limit, has cast pistons in it instead. Cylinder pressures are highest at lower engine speeds, and this problem is exacerbated by adding a supercharger. Dizduster brings up a good point regarding timing but that is only one piece of the puzzle.
Re: 700 N/A vs 700 Blown [Re: Blusmbl] #1804557
04/15/15 11:45 PM
04/15/15 11:45 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Blower looks kewler!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 700 N/A vs 700 Blown [Re: hemi-itis] #1804867
04/16/15 12:16 PM
04/16/15 12:16 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not if they're slow..............looks funny in that case, kinda like a wing on a honda.
Re: 700 N/A vs 700 Blown [Re: Thumperdart] #1805046
04/16/15 04:37 PM
04/16/15 04:37 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Both are cool, N/A or supercharged. What I take from this is 700 forced induction HP will be easier to live with, better on fuel etc. Not saying that 700 N/A HP can't drive long distances or on the street regularly (ThumperDart and sixpackgut both proved it), but again a forced induction engine will do it a lot better, likely less maintenance and likely be faster with a compromised (streetable) set up. Look at Dizusters Savoy, 9 sec whip that idles like it's almost stock! No crazy gears of convertor needed
Page 2 of 3 1 2 3
