Page 1 of 7 1 2 3 4 5 6 7
The turbo Cuda build has begun #180163
01/01/09 12:06 AM
01/01/09 12:06 AM
Jarrettsville, MD
cudaman1967 Offline OP
Jarrettsville, MD
Turbo is located and passenger header is built. Friday will build the drivers side.
Cudaman1967 1967 Barracuda Turbo Outlaw 8.50
Re: The turbo Cuda build has begun [Re: cudaman1967] #180164
01/01/09 12:31 AM
01/01/09 12:31 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
What size of turbo ?
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: The turbo Cuda build has begun [Re: go green] #180165
01/01/09 09:36 AM
01/01/09 09:36 AM
Jarrettsville, MD
Jarrettsville, MD
Bullseye 80mm with 1.32 a/r
Re: The turbo Cuda build has begun [Re: cudaman1967] #180166
01/01/09 09:47 AM
01/01/09 09:47 AM
MR_P_BODY Offline
MR_P_BODY  Offline
cool
Re: The turbo Cuda build has begun [Re: cudaman1967] #180167
01/01/09 09:50 AM
01/01/09 09:50 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Same turbo I now have..... I just got mine fired up last weekend with the new BW Bullseye S480 with 1.32AR, changing converter today & hopefully can get it out & see how it spools.
What CID?
Cam specs?
What size primaries & collectors did you end up going with?
Re: The turbo Cuda build has begun [Re: RyanJ] #180168
01/01/09 11:40 AM
01/01/09 11:40 AM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
From what I can see on the topside of that motor, you will be using that turbos potential up fairly easy!
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: The turbo Cuda build has begun [Re: RyanJ] #180169
01/01/09 01:32 PM
01/01/09 01:32 PM
Jarrettsville, MD
Jarrettsville, MD
Not sure yet on the bore it will be no bigger than 446. The new block is over at the machine shop as of Monday. Mach Machine does all my machine work. He builds alot of nitrous pro mod motors. The cam is is a lunati solid. Mach hooked me up with his guy Steve at Lunati who does lots of turbo grinds.
Primaries are 2" into a 3" collector. The crossover will also be 3".
Converters are tricky with turbos. If you need help with that let me know. I have guru that has special converters he does for turbo cars.
Re: The turbo Cuda build has begun [Re: cudaman1967] #180170
01/01/09 10:27 PM
01/01/09 10:27 PM
Jarrettsville, MD
Jarrettsville, MD
Passenger header
Re: The turbo Cuda build has begun [Re: cudaman1967] #180171
01/01/09 10:32 PM
01/01/09 10:32 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
So when are you gonna have it at Capitol?
Re: The turbo Cuda build has begun [Re: Kevins493] #180172
01/01/09 11:04 PM
01/01/09 11:04 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Mike what the heck are you up to ?? Ron
Re: The turbo Cuda build has begun [Re: Kevins493] #180173
01/01/09 11:09 PM
01/01/09 11:09 PM
Jarrettsville, MD
Jarrettsville, MD
Shooting for April. We should be done with all the piping by Sunday or Monday. Motor will be done sometime in Feb. Then it will be time to fine tune
Re: The turbo Cuda build has begun [Re: 383man] #180174
01/01/09 11:10 PM
01/01/09 11:10 PM
Jarrettsville, MD
Jarrettsville, MD
Hey Ron!
Going back on the street! Wanted something different. Not many turbo BB Mopars out there.
Re: The turbo Cuda build has begun [Re: cudaman1967] #180175
01/01/09 11:36 PM
01/01/09 11:36 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Hey Ron!
Thats cool. We can cruise together sometimes if I can keep up with you. Ron
Re: The turbo Cuda build has begun [Re: RyanJ] #180176
01/01/09 11:52 PM
01/01/09 11:52 PM
Here
jcc Offline
jcc  Offline
Here
What CID?
Cam specs?
And what CR?
"When one’s appeal is emotional, it does not matter if there is no substance."
Re: The turbo Cuda build has begun [Re: jcc] #180177
01/02/09 12:08 AM
01/02/09 12:08 AM
Jarrettsville, MD
Jarrettsville, MD
9.0:1
Re: The turbo Cuda build has begun [Re: cudaman1967] #180178
01/02/09 05:44 PM
01/02/09 05:44 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Cool, looks good. Wish mine had all that room around front end. I like the way you did the turbo mount also with the T6 flange.
I gotta fix my wastegate I pegged the gauge at 20 PSI twice yesterday
You won't have any trouble spooling that S480, mine is putting out around 3 PSI at 2500 RPM & my exhaust system is way way too big & only 394 inches. Boost is definitely addicting.... turns a mild mannered motor into a video game like animal.
Power? not a problem... keeping it on the road & out of the ditches... may be a problem
Re: The turbo Cuda build has begun [Re: RyanJ] #180179
01/02/09 09:20 PM
01/02/09 09:20 PM
go green Offline
go green  Offline
Spell check on the valve cover !
Re: The turbo Cuda build has begun [Re: cudaman1967] #180180
01/02/09 09:27 PM
01/02/09 09:27 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
Hoping to have mine ready by then, maybe a little earlier. Gotta fix the motor and put it back in.
Re: The turbo Cuda build has begun [Re: Kevins493] #180181
01/02/09 10:01 PM
01/02/09 10:01 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
No inner-cooler???? Are you running Methanol for fuel, or Water Injection...
How fast are you wanting to go, how much boost?
Post deleted by Defbob [Re: cudaman1967] #180182
01/02/09 10:21 PM
01/02/09 10:21 PM
