Re: 700 N/A vs 700 Blown
[Re: hudsonhornet7x]
#1800720
04/10/15 11:20 PM
04/10/15 11:20 PM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
If they both make the same power, I would take the one that made the most torque at the given torque/HP curve I desired.
11B40
#1800745
04/10/15 11:49 PM
04/10/15 11:49 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
My head says the blown motor will have more torque, a milder idle and properly tuned, be more street friendly. My heart says nothing sounds as good as a high compression engine with a lopey idle, and that anything else sounds boring.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#1800749
04/10/15 11:51 PM
04/10/15 11:51 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
My head says the blown motor will have more torque, a milder idle and properly tuned, be more street friendly. My heart says nothing sounds as good as a high compression engine with a lopey idle, and that anything else sounds boring. I agree, while I like the blown or turbo better power wise, nothing sounds like a nasty motor with a big lopey lope cam. But a blower motor with extreme blower surge at idle is pure sex also ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
#1800814
04/11/15 12:37 AM
04/11/15 12:37 AM
Posts: 4,255 Canada
WO23Coronet
Canada
On paper they should be equally as quick, but realistically the blower motor would get there easier and would be a lot more fun to drive. I also think the blower motor would be quicker with a not so ideal set up (who ever has a perfectly dialed in set up). I'd go forced induction
[Re: WO23Coronet]
#1800820
04/11/15 12:42 AM
04/11/15 12:42 AM
Posts: 1,543 USA
hudsonhornet7x
USA
Thank you guys for the help, believe it or not this is a high school shop class project, you might have read about it in Chrysler Power. We have a chance to build a supercharged engine and it will be a first for us.
Picture this: 6.4 " Hellcat esque" blown motor, caged, General Lee fresh off the rotisserie.
Think Galen would certify that as a 1 of 1 lol.
#1800928
04/11/15 10:40 AM
04/11/15 10:40 AM
Posts: 12,260 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The blower motor should have a flatter torque curve and hold more torque longer so it would have an performance advantage in the real world. Is budget an issue? The blower stuff will take more coin than the N/A.
Master, again and still
[Re: Evil Spirit]
#1801028
04/11/15 01:02 PM
04/11/15 01:02 PM
Thumperdart
State of confusion
My head says the blown motor will have more torque, a milder idle and properly tuned, be more street friendly. My heart says nothing sounds as good as a high compression engine with a lopey idle, and that anything else sounds boring. I agree cos we've all seen too many slower than they should be blower motors and a FEW fast n/a cars.........
[Re: Thumperdart]
#1801043
04/11/15 01:41 PM
04/11/15 01:41 PM
Posts: 43,293 Bend,OR USA
Cab_Burge
I would think of how much added strain driving the blower makes on the motor, compressing air driven off the crankshaft takes HP and adds strain on every part of the motor, before making the final decesion. As far as turbos I've been told that( by racers who use them) they do add additional concerns off the back side of the motor so I guess there are no free lunches. Adding boost into a motor definetily makes more power easier per C.I. than N/A motor do.
#1801127
04/11/15 05:00 PM
04/11/15 05:00 PM
Posts: 4,210 New York
polyspheric
New York
And as we all know, that rilly kewl sound is why we build motors...
Boffin Emeritus
[Re: Cab_Burge]
#1801282
04/11/15 09:22 PM
04/11/15 09:22 PM
Posts: 8,182 Plymouth, MI
Blusmbl
Plymouth, MI
I would think of how much added strain driving the blower makes on the motor, compressing air driven off the crankshaft takes HP and adds strain on every part of the motor, before making the final decesion. As far as turbos I've been told that( by racers who use them) they do add additional concerns off the back side of the motor so I guess there are no free lunches. Adding boost into a motor definetily makes more power easier per C.I. than N/A motor do. It can take 100+ extra horsepower to drive a supercharger even on a mild 600-700hp street engine, so the entire rotating assembly is going to see additional stress from the cylinder pressures over an n/a motor. However, for the same displacement the n/a motor would have to spin at higher rpm, which requires more expensive valvetrain components. Both are cool. I like torque so I prefer big blocks, or supercharged/turbocharged smaller displacement engines.
[Re: Pale_Roader]
#1801632
04/12/15 12:51 PM
04/12/15 12:51 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
That wasn't a Shivvy, that was a Ram with a 420" Gen III Hemi.
Mopar to the bone!!!
[Re: Blusmbl]
#1801641
04/12/15 01:03 PM
04/12/15 01:03 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Cranks see maximum stress near TDC. Because boosted motors run less timing, the cranks actually see a lot less stress vs. a N/A motor.
