Educate me on my 47RE
#1799086
04/09/15 01:19 AM
04/09/15 01:19 AM
Posts: 147 Alberta, Canada eh!
70Cudha
Alberta, Canada eh!
Sorry if this has been asked in the past. I have a 2003 (built Sept 02) Ram 2500 with the 5.9L (250) Cummins SMARTY JR programmed with an additional 70hp for towing and the 47re 4 speed overdrive auto running 3.73 in the diffs. My issue is with towing my 26' enclosed car hauler and steep grades. In 3rd gear the diesel is cranking 2300rpm at 60mph. In overdrive it drops to 1800rpm at the same speed however on hills I drop revs and running below that I'm worried I'll burn up that tranny. The problem is the big jump or loss in power between 3rd and 4th. Any suggestions for mods to the existing tranny to help keep it all together and not grenade the tranny? Thx in advance.
1970 EV2 Barracuda Hardtop 1970 FE5 Barracuda Gran Coupe Convertible 1969 B5 Dart GTS 383 1968 TT1 Barracuda Convertible 1997 Ram SS/T 2008 3500 Ram Diesel
Re: Educate me on my 47RE
[Re: 70Cudha]
#1800949
04/11/15 11:13 AM
04/11/15 11:13 AM
Posts: 6,229 ohio
ruderunner
ohio
Downshift or use the OD lockout when hitting steep grades. That's what it's for.
There's several reasons to drop a gear, all center around heat. Heat that damages the trans and engine.
At lower engine speeds it takes more boost and fueling to create the same power, this drives up EGTs and can hurtthe turbo and possibly burn valves. 2300 rpm is a cake walk for theCummins and better than lugging at 1800. If you have egt readout try to stya below 1300.
At lower rpm the torque conveter is being worked hard and building lots of heat. Higher rpm puts the converter closer to it's optimum speed creating less heat buildup.
As for loss of power, when dropping a gear you do have to add more throttle. The engine is spinning faster and moving more air, you need to add fuel to keep up.
Maybe this is something that you can tune with the programmer?
Angry white pureblood male
[Re: redraptor]
#1802113
04/13/15 12:13 AM
04/13/15 12:13 AM
70Cudha
Alberta, Canada eh!
Sorry boys guess my title was misleading and I wasn't clear. I'm researching what modifications others have made to their 47re tranny's to overcome the obvious issues when towing.
[Re: 70Cudha]
#1802250
04/13/15 09:04 AM
04/13/15 09:04 AM
Posts: 21,054 in a cattle trailer down by th...
Guitar Jones
Sorry boys guess my title was misleading and I wasn't clear. I'm researching what modifications others have made to their 47re tranny's to overcome the obvious issues when towing. Go to the PATC web site (google search PATC) they have everything you could possibly need to grenade proof your 47RE.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#1802353
04/13/15 01:21 PM
04/13/15 01:21 PM
70Cudha
Alberta, Canada eh!
Guitar Jones Yes. Looks like PATC offers up to 5 levels of upgrades to consider. Thanks for the lead.
[Re: 70Cudha]
#1804702
04/16/15 02:09 AM
04/16/15 02:09 AM
Posts: 3,933 Oregon
hooziewhatsit
There was another mod to the oiling holes in the OD section you could do while it was apart. I'll have to see if I can find it again.
[Re: hooziewhatsit]
#1804957
04/16/15 02:35 PM
04/16/15 02:35 PM
Posts: 26,470 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The shaft mod is to drill this hole out to 3/16"
