Measuring ring gear diameter? #1799556
04/09/15 04:42 PM
04/09/15 04:42 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
I'm trying figure out the diameter of a ring gear. Do you measure it at the very outer edge teeth. When I do I come up with 8-3/4" I hoping that is what I have.
Re: Measuring ring gear diameter? [Re: rarefish] #1799938
04/09/15 11:20 PM
04/09/15 11:20 PM
just WAG ing. it'd either have to the the OD (likely) or the ID (least likely I'd think) or C to C (maybe) which'd be between ~ the (1) and the (8) on your tape (7"). I'd do all three & see if one of em is 7&1/4/8&1/4/9&1/4/9&3/4. Here's a BTT for ya
Re: Measuring ring gear diameter? [Re: rarefish] #1800101
04/10/15 09:48 AM
04/10/15 09:48 AM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Actually, I found the part number and date code on the ring gear. It matched up with one in my 70-71 parts book and it is a 8-3/4" ring gear.
Re: Measuring ring gear diameter? [Re: rarefish] #1800112
04/10/15 09:59 AM
04/10/15 09:59 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
So now you have to figure which case its for ... 489, 742 or 741. You do have the pinion, right ???
Re: Measuring ring gear diameter? [Re: Stanton] #1800175
04/10/15 11:14 AM
04/10/15 11:14 AM
New York
rarefish Offline OP
rarefish  Offline OP
New York
I do have the matching pinion. It is a 1-3/4" so the gear set is for the 742 case
Re: Measuring ring gear diameter? [Re: rarefish] #1800374
04/10/15 02:50 PM
04/10/15 02:50 PM
dogdays Offline
dogdays  Offline
It's always the OD of the gear. The gear outside the contact patch isn't that important, so they sometimes are a little smaller OD than the name would suggest.
When hypoid gearsets are made, they get put into a machining setup and the pinion and ring are assembled and run with lapping compound for a brief time. That makes them a set, and unless you're building a rear to get out of the Yukon or a place like that, sets are never broken up. Pinions aren't swapped out without changing the ring gear to the matching one. I put this last paragraph in for the newbies out there.
R.
