actual end date of left handed wheel lugs? #1798814
04/08/15 08:29 PM
04/08/15 08:29 PM
Social Republic of California
fc7vw9 Offline OP
fc7vw9  Offline OP
I am working on 11" front drum brakes off my 71 cuda. Pressed out studs, 5 lefts, 5 rights, both drums are aug70 casting. So I checked rear axle, 5 lefts, 5 rights? Everything I have read said Model year 70 was last of the Left studs? or is in calender year 70? SPD was Nov 9 70.
Looking for opinions.
Thank you
Re: actual end date of left handed wheel lugs? [Re: fc7vw9] #1798886
04/08/15 09:49 PM
04/08/15 09:49 PM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
Probably drums/axles from a donor '70 - swapped in sometime before you took over ownership...take the LH studs out and put in the correct RH studs.
Re: actual end date of left handed wheel lugs? [Re: fc7vw9] #1798924
04/08/15 10:31 PM
04/08/15 10:31 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
When in doubt, look for a factory technical service bulletin;
http://www.hamtramck-historical.com/images/TSBs/1971/71-22-1.jpg
Re: actual end date of left handed wheel lugs? [Re: fc7vw9] #1798930
04/08/15 10:45 PM
04/08/15 10:45 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I believe it was 70 for cars. All my 71's have right hands. Now my 73 W200 that my dad bought new came with lefties.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: actual end date of left handed wheel lugs? [Re: fc7vw9] #1798940
04/08/15 10:55 PM
04/08/15 10:55 PM
fc7vw9 Offline OP
fc7vw9  Offline OP
Thank you Barry That TSB is dated Aug 1970, so parts built up to sometime in August 70 were left handed threads?
Ron
Re: actual end date of left handed wheel lugs? [Re: fc7vw9] #1799246
04/09/15 11:03 AM
04/09/15 11:03 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Why not just leave them in, unless you are doing a concourse resto..... Works great having all left hand studs like 99% of all cars on the road...
Re: actual end date of left handed wheel lugs? [Re: minivan] #1799270
04/09/15 11:41 AM
04/09/15 11:41 AM
fc7vw9 Offline OP
fc7vw9  Offline OP
I am just trying to put the car back to the way MA Mopar built it. I know the axles were in and out as the car had 456 gears in it, (it came with the original 391s in a bucket) and the original k frame was out of the car. It had 71 B body Hemi K frame in it, (car had a hemi when I bought it, seller kept hemi said it was out of a 71 roadrunner?). But I have a hard time believing that the front hubs were changed out.
Re: actual end date of left handed wheel lugs? [Re: fc7vw9] #1799291
04/09/15 12:19 PM
04/09/15 12:19 PM
Back in Blue Jersey.
P
polara71 Offline
polara71  Offline
P
I have had two early build 71 Polaras [ August & September ] that had left handed threads. It's been my experience that sometime in mid September they made the switch....for Cs anyway
Re: actual end date of left handed wheel lugs? [Re: minivan] #1799397
04/09/15 02:07 PM
04/09/15 02:07 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
99% of all cars on the road ???
Pretty sure only Chrysler used left hand thread ...
And it's not 1970 anymore ... or did we time warp ?
Re: actual end date of left handed wheel lugs? [Re: JohnRR] #1799748
04/09/15 09:28 PM
04/09/15 09:28 PM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
Is there evidence of any inspector's paint remaining on the studs - from both sides?
Wanted to add, Moparts.com is still the BEST, major props go out to our mods and care takers.
The pics are of the rear axle studs from the June, 1970 Hamtramk Barracuda I have. If they are the original axles to my car's rear, then may be typical of what to expect when viewing the survivor and OE class of E bodys . Maybe even early '71's.
Definitely hold off on taking my earlier advice above - not until you get an agreed on answer here, yes keep it original. '71's are my favorite year, good for you my man.
Re: actual end date of left handed wheel lugs? [Re: ebodyseast] #1799849
04/09/15 11:08 PM
04/09/15 11:08 PM
fc7vw9 Offline OP
fc7vw9  Offline OP
Thank you for the pictures. Yes the stud holes in the axles have those paint colors. We are checking pictures for the fronts as we were disassembling.
Re: actual end date of left handed wheel lugs? [Re: JohnRR] #1800503
04/10/15 07:16 PM
04/10/15 07:16 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I got that backwards didn't I.....
Re: actual end date of left handed wheel lugs? [Re: minivan] #1800672
04/10/15 10:31 PM
04/10/15 10:31 PM
U.S.S.A.
U.S.S.A.
yes you did sir ... wink
Re: actual end date of left handed wheel lugs? [Re: minivan] #1800686
04/10/15 10:43 PM
04/10/15 10:43 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Just as an oddball trivia, toyota (at least in Australia) had LH thread as well (in 12mm)...in the 70s (not sure for how long or anything) I just know we had a customer asking about them before. laugh2
Re: actual end date of left handed wheel lugs? [Re: OzHemi] #1800718
04/10/15 11:19 PM
04/10/15 11:19 PM
fc7vw9 Offline OP
fc7vw9  Offline OP
I'll take left handed wheel lugs for $200 Alex. boogie
Re: actual end date of left handed wheel lugs? [Re: fc7vw9] #1800722
04/10/15 11:23 PM
04/10/15 11:23 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I could have bought a couple thousand 9/16" LH ones as well on closeout from my supplier....another oddball size. laugh2
Re: actual end date of left handed wheel lugs? [Re: fc7vw9] #1800724
04/10/15 11:24 PM
04/10/15 11:24 PM
fc7vw9 Offline OP
fc7vw9  Offline OP
The left hub had red on inside of stud holes, in the picture its an a card so I have get it to my computer to post. A couple of the studs show some copper color where it was pressed against the back of the hub.....seems like the bottom on the crate.
Re: actual end date of left handed wheel lugs? [Re: fc7vw9] #1800933
04/11/15 10:43 AM
04/11/15 10:43 AM
U.S.S.A.
U.S.S.A.
Aftermarket left hand studs I bought in the 80's early 90's were copper colored .
Re: actual end date of left handed wheel lugs? [Re: OzHemi] #1800934
04/11/15 10:45 AM
04/11/15 10:45 AM
U.S.S.A.
U.S.S.A.
Would a left hand thread on the underside of the world actually be right hand ?
Re: actual end date of left handed wheel lugs? [Re: JohnRR] #1800961
04/11/15 11:26 AM
04/11/15 11:26 AM
New York
rarefish Offline
rarefish  Offline
New York
GM used left hand threads on some models in the early 60's
