Page 2 of 3 1 2 3
Re: are the dana 60 truck rearends worth anything? [Re: Dougo3] #17999
11/07/05 12:53 AM
11/07/05 12:53 AM
Montgomery, AL
v8440 Offline
v8440  Offline
Montgomery, AL
A dana 70 is probably not something you'd want to use in a car. After the 60, they get much heavier. A 70 is closer to a dana 80 in weight and probably strength if I remember right. I have a dana 80 lying around in my shop, and believe me, that's a big heavy sonofabitch!
Exactly 610 posts on old board, first whacked post in the history of this one! Funny moparts quote from Waginator: "*If you want your package lost, like bermuda triangle lost, use DHL (formerly airborne) *if you want it to get there but destroyed, use UPS."
Re: are the dana 60 truck rearends worth anything? [Re: Dougo3] #18000
11/07/05 01:22 AM
11/07/05 01:22 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
DirectSubjection have you seen the Warriors video game?
Yeah - I just bought it but haven't tried it yet. I picked up a new 34" TV and moved the PS onto it but haven't turned the game box on yet to see if I screwed up the install.
Working on the PC version of Call Of Duty II right now.
And I agree - 70s, 80's, GM 14-bolts etc are not suited for car use.
Ride eternal, shiny and chrome
Re: are the dana 60 truck rearends worth anything? [Re: I_bleed_MOPAR] #18001
11/07/05 02:29 AM
11/07/05 02:29 AM
Candler, NC
Roughrdr Offline
Roughrdr  Offline
Candler, NC
[quoteThe only drawback is the truck housings have no provisions for a snubber.
Tim
They can be machined easy for one though.
Chains of habit - too light to be felt until they are too heavy to be broken
Re: are the dana 60 truck rearends worth anything? [Re: Roughrdr] #18002
11/07/05 08:08 PM
11/07/05 08:08 PM
Kansas City
MOPARHOUND Offline
super gas
MOPARHOUND  Offline
super gas
Kansas City
Scored one over the weekend from a 1976 Dodge 1 ton motor home chassis. Has 60HD cast on the center section.
I have heard of guys mounting the pinion snubber upside down on the body of the car.
You weld on 8-3/4 ends, after cutting off the truck "full floating ends", with the width you need for your car presumably?
Custom axles then?
Can't get the brake drum loose on one end, the guy I bought it from wants to keep them. Thought about torching the studs holding the backing plate on, and then accessing the brake assembly through the 3"-4" hole the axle tube goes through. The guy beat the adjuster to death with a chisel, and took the brake cylinder loose and pushed it down into the drum.
Any ideas (pic)?
(Don't mean to hijack thread, hopefully others will learn something to doing this conversion).
My car club: hpacmopar.com
1971 Charger R/T, 496" RB Stroker, Auto, Driven Daily
Re: are the dana 60 truck rearends worth anything? [Re: MOPARHOUND] #18003
11/07/05 08:10 PM
11/07/05 08:10 PM
Kansas City
MOPARHOUND Offline
super gas
MOPARHOUND  Offline
super gas
Kansas City
Pic showing full floating versus semi-floating attached.
Re: are the dana 60 truck rearends worth anything? [Re: MOPARHOUND] #18004
11/07/05 08:15 PM
11/07/05 08:15 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
IIRC, 60HDs have 3 1/2" axle tubes? (Standard 60s have 3" like 8 3/4s? )
Where's DrDiff when you need him?
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: are the dana 60 truck rearends worth anything? [Re: I_bleed_MOPAR] #18005
11/07/05 08:23 PM
11/07/05 08:23 PM
Hudson Mass
67Mopar Offline
67Mopar  Offline
Hudson Mass
I need to get the lay person scoop on this, I know of alot of dodge trucks in a junky up in Maine
Re: are the dana 60 truck rearends worth anything? [Re: 67Mopar] #18006
11/07/05 08:30 PM
11/07/05 08:30 PM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
What's the difference in bolt patterns? I saw a Dana in an old dart in a yard here and it had a HUGE bolt pattern. Are the axles interchangable? After hearing $650 for a A-body 8 3/4 in the same yard, I didn't even bother asking about the Dana.
Re: are the dana 60 truck rearends worth anything? [Re: Hotwheelsjr] #18007
11/07/05 09:29 PM
11/07/05 09:29 PM
Buford, GA
Buford, GA
Most standard 60s are in 3/4 and 1T trucks and vans and are 8 lugs w/ full floating axles. There are some 60s in late 70s (?) Ford trucks that are 5 lug and semi-floating axles. I'm almost positive the 60 HDs have bigger axle tubes than a standard 60. Maybe DrDiff or someone with a little more knowledge will chime in.
Tim
'71 Charger 383/727
Re: are the dana 60 truck rearends worth anything? [Re: I_bleed_MOPAR] #18008
11/07/05 09:35 PM
11/07/05 09:35 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
there are also some Dana 61s out there too
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: are the dana 60 truck rearends worth anything? [Re: AZ_A12_BEE] #18009
11/07/05 09:46 PM
11/07/05 09:46 PM
oregon
smokey Offline
super street
smokey  Offline
super street
oregon
some D60s have a mount for a snuber i got one that was out of a 77 dodge truck it had the pad mount just the holes were not driled it had them cast there just not drilled
drag racers know where the finish line is....they don't have to drive around in circles looking for it !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Re: are the dana 60 truck rearends worth anything? [Re: smokey] #18010
11/07/05 10:55 PM
11/07/05 10:55 PM
Kansas City
MOPARHOUND Offline
super gas
MOPARHOUND  Offline
super gas
Kansas City
Great pic Smokey. Makes you wonder if it came from the same molds some of the last car rears were made from.
Just eyeballing the Dana 60HD compared to the 69 and 71 car Dana 60s, the 60HD tubes appear to be thicker, but maybe by a 1/4" or so. Also, the tubes taper down a fraction in thickness a few inches before the backing plates on the 60HD, whereas the car Danas taper up in thickness???
The numbers on the 60HD are 6 7 5, meaning June 7, 1975.
The B.O.M. # is 603514 - 2, (5 is pitted, my best guess). Haven't been able to find this number on the internet, but did find a 603516 for a Dana B.O.M. The 60HD was cast in on the front side of the center housing.
The rear had dual wheels on it, but it is not a sure-grip unit.
The ratio tag has 11 on top, and 4? something on the bottom of it. I could only find one ratio with 11 for the pinion gear, so I presume the ratio is 3.73.
Re: are the dana 60 truck rearends worth anything? [Re: MOPARHOUND] #18011
11/07/05 11:14 PM
11/07/05 11:14 PM
Nova Scotia Canada B2Y 1E4
SANDYinNS Canada Offline
I bought a 91 ram van for the 360...the guy who sold it to me, told that it didn't have an od tranny......well it does and being a 3/4 ton it had a dana 60.
I took a quick look for the equipment sticker and couldn't find it. I figure pull the cover off the dana and I'll be able to see the ratio.
I pay for the van a whopping $300 and the guy gives me the title....then he hands me the sticker...BONUS 4:10 sure grip!
Sandy in Nova Scotia formerly drdodge340
68 coronet wagon, 68 formula s 340 fb barracuda-69 super bee-72 aussie charger-72 aussie vh dodge ute
-76 feather duster-76 duster-77 street van
- 98 ram 1500 SS/T-99 ram 1500-13 ram red express truck- 2015 hellcat challenger
Re: are the dana 60 truck rearends worth anything? [Re: SANDYinNS Canada] #18012
11/07/05 11:26 PM
11/07/05 11:26 PM
I have 2 of these that are from mid-late 60's trucks and i need a rear for the dart not to jack the post but how much are we talking to set it up for 5 on 4.5 and narrow it a little and use the 4.10 SG center it already has? Thanks guys...
Re: are the dana 60 truck rearends worth anything? #18013
11/07/05 11:30 PM
11/07/05 11:30 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
if you cut the tube and install 8.75 housing ends, can you use the 8.75 axels in the D60?
Re: are the dana 60 truck rearends worth anything? [Re: Dakota_Don] #18014
11/08/05 12:41 AM
11/08/05 12:41 AM
Kansas City
MOPARHOUND Offline
super gas
MOPARHOUND  Offline
super gas
Kansas City
Dakota Don, that was my question on page one, custom axles??
Here is a link to a chart with some of the various dimensions and spline counts:
http://www.autohobbydigest.com/dana.html
Good quote from the article:
"When installing truck differentials in cars, it is usually necessary to replace the differential gears which the axle shaft splines engage (part 55 in Figure 1). These are readily available for 1-1/2"x35 spline axle shafts as are the pinion gears and shafts (parts 53 and 54 in Figure 1)."
Re: are the dana 60 truck rearends worth anything? [Re: AZ_A12_BEE] #18015
11/08/05 09:48 AM
11/08/05 09:48 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
You can find them in ford vans....ask me how I know.
Re: are the dana 60 truck rearends worth anything? [Re: Dakota_Don] #18016
11/08/05 09:55 AM
11/08/05 09:55 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
if you cut the tube and install 8.75 housing ends, can you use the 8.75 axles in the D60?
It can be done but from what I understand its a waste of time. They old ends are usually damaged or way oversize and new ones are around $70
Re: are the dana 60 truck rearends worth anything? [Re: MOPARHOUND] #18017
11/08/05 10:19 AM
11/08/05 10:19 AM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
Ty moparhound for the link..
Re: are the dana 60 truck rearends worth anything? [Re: Dakota_Don] #18018
11/08/05 10:35 AM
11/08/05 10:35 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
I just had a dana 60 truck housing cut to size for my road runner. The mopar ends were welded on. You can use the ford ends if you with to use the svo rear disk kit (Like available from Dr Diff)
The Red circle is where the "60" is marked to ensure you get the correct housing
The Green Circle shows the new Mopar ends welded on.
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Page 2 of 3 1 2 3
