Re: XE268 in 440?????????????????????
[Re: gch]
#1797906
04/07/15 10:13 PM
04/07/15 10:13 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
I would rather have the 270 magnum for the "muscle car" sound.
The 268 will be a smooth torque motor with a hint of idle.Headers will help it sound a little healthier. I agree and better yet call Tim @ Bullet cams for a great grind for your combo.
[Re: 1BaadBee]
#1797981
04/07/15 10:57 PM
04/07/15 10:57 PM
Posts: 3,087 Michigan
A727Tflite
I installed a XE268 in a customer's 68 runner that had 9.5 to 1, DP4B with the AVS, 906 heads with standard size valves, factory exhaust manifolds. Took out a 284 Purple Shaft that gave less than 10" of vacuum. The car sounds like a new street hemi used to, has 16" of vacuum and fries the tires with a 3.23 in low gear when you mat the throttle. I installed it straight up, no cam advance.
[Re: 1BaadBee]
#1798180
04/08/15 12:53 AM
04/08/15 12:53 AM
Posts: 1,652 Amarillo, Tx
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
I have ran the 268xe in my 440 for 2 years. Love it. Great driveability, slightly lopey idle and like Transman said, nail the throttle, and it cooks the tires. I am installing the freshly built 440 I have been working on for my swb D150 and it also has a 268xe. Stock converter works well, as do power brakes. I've had other cams in 440s in a truck, but hands down I like the 268 best. I too installed it straight up.
84 D150 440/727 79 /6 swb D150 1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
[Re: 1BaadBee]
#1798401
04/08/15 12:06 PM
04/08/15 12:06 PM
Posts: 4,780 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Is the low vacuum your only dislike of your current cam? I ask because for about $260 you could install an electric pump to produce all the brake vacuum you need and its always there.
Keep old mopars alive.
[Re: 1BaadBee]
#1798783
04/08/15 07:55 PM
04/08/15 07:55 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
For the price of an off the shelf cam you cna get a custom grind from Comp. Call them and have them spec a cam for your exact build.
[Re: 1BaadBee]
#1798958
04/08/15 11:14 PM
04/08/15 11:14 PM
Posts: 797 WA
pro451bee
WA
XE268 sounds mean in my 451 ,worked good in a 383 too, hits the rev limiter very quickly , set at 6200 ,pulls overdrive like a super star . Would like to try a Mopar 528 solid tho.
