Re: 8 3/4 Axle end play
[Re: BADDBOB]
#1797779
04/07/15 08:17 PM
04/07/15 08:17 PM
Posts: 4,848 Memphis
HemiRick
Memphis
The adjuster screws in to eliminate the play.....
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#1797916
04/07/15 10:19 PM
04/07/15 10:19 PM
RapidRobert
If going the right way doesn't take care of it, what was changed on your setup from before?
[Re: HemiRick]
#1797921
04/07/15 10:21 PM
04/07/15 10:21 PM
Posts: 43,163 Bend,OR USA
Cab_Burge
The adjuster screws in to eliminate the play..... I agree, OP screw the adjuster in to remove the end play, shoot for .005 to .010 max end play on the adjuster side, same amount on the other side.
