Re: 1970 rr help
[Re: hemipowered2]
#179759
12/31/08 03:33 PM
12/31/08 03:33 PM
Posts: 11,854 Georgetown Ontario Canada
anlauto
Where exactly does it not fit? The rear of the spring or the front of the spring? I'm not sure what you're talking about. The rear suspension should have enough play to move the springs side to side to get everything hooked up? 1/2 inch isn't that far??
CHECK OUT MY NEW WEB SITE !
Re: 1970 rr help
[Re: junkman]
#179763
12/31/08 06:03 PM
12/31/08 06:03 PM
Re: 1970 rr help
[Re: topside]
#179765
12/31/08 08:10 PM
12/31/08 08:10 PM
Posts: 1,567 Ky
jt4406
Ky
Maybe you can back the nuts off the front spring hangers until they are flush with the ends of the studs, then pry the hangers rearward to hook up the rear shackels, then tighten the front spring hanger studs back up? jt
Yeah, it's hopped up to over 160...
Re: 1970 rr help
[Re: RoadRunnerJD]
#179772
01/02/09 02:53 PM
01/02/09 02:53 PM
Posts: 408 Manhattan, IL
SixPackRT
Manhattan, IL
Were the rear frame rails on the car replaced? And if they were did you replace them with stock plymouth frame rails? I believe (am sure) there is a difference between dodge and plymouth frame rails as far as rear spring mounting locations. The front hanger is also different but that would move your spring location back, not forward if you were using front hangers from a dodge. So I wouldn't think that was the problem. But if you replaced the rear frame rails this may be something for you to look at. Just my Scott
70 Coronet RT 440+6 64 Dodge 330 - Future Hemi Clone 17 Challenger Hellcat - Green Go Driver 86 Buick T-Type Turbo V-6
