AV GAS
#1797289
04/07/15 12:44 PM
04/07/15 12:44 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Just curious if any of you folks run it and how it compares to race gas.
Re: AV GAS
[Re: Thumperdart]
#1797314
04/07/15 01:11 PM
04/07/15 01:11 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Ran it for years in a 12.5:1 440 and never had any problems. Ran as good as VP 110 in that motor.
Re: AV GAS
[Re: an8sec70cuda]
#1797438
04/07/15 02:53 PM
04/07/15 02:53 PM
Thumperdart
State of confusion
That's what I have been hearing. .......Thankxx
Re: AV GAS
[Re: Thumperdart]
#1797657
04/07/15 05:58 PM
04/07/15 05:58 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I always use to put it in the challenger when I was racing the car. A guy that works on lawnmowers just told me to use it whenever possible instead of pump gas
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: AV GAS
[Re: sixpackgut]
#1797728
04/07/15 07:07 PM
04/07/15 07:07 PM
Thumperdart
State of confusion
Should be in Vegas next month and don't want to mess with E 85 so figured I'd try some.
Re: AV GAS
[Re: super451b]
#1797756
04/07/15 07:45 PM
04/07/15 07:45 PM
Challenger 1
Cincinnati, Ohio
Been running it for years. Car runs the same as it did on Sunoco 110 . 11.2:1 engine . I always mix in a little Lucas top end lube with it . What's the purpose on the upper lube?
Re: AV GAS
[Re: Challenger 1]
#1797887
04/07/15 09:59 PM
04/07/15 09:59 PM
Posts: 854 Bloomingdale , OH
super451b
Bloomingdale , OH
Been running it for years. Car runs the same as it did on Sunoco 110 . 11.2:1 engine . I always mix in a little Lucas top end lube with it . What's the purpose on the upper lube? To be honest , I really dont know. When I made the switch , it was at the recommendation of friends that had been running it for years . They told me to add the lube ,so as a matter of practice, I have always used it .
Re: AV GAS
[Re: Thumperdart]
#1797961
04/07/15 10:39 PM
04/07/15 10:39 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
So do you guy's know someone at the airport? the air ports I've been to have the area all fenced in and you have to go through the building , then through a locked door. If you don't have a plane, you don't get passed that door.
Re: AV GAS
[Re: rowin4]
#1798170
04/08/15 12:45 AM
04/08/15 12:45 AM
Posts: 159 australia
charger410
australia
So do you guy's know someone at the airport? the air ports I've been to have the area all fenced in and you have to go through the building , then through a locked door. If you don't have a plane, you don't get passed that door. That's what it's like over here now. I used to use it in a 282ci hemi 6 with 12.9 comp, solid lifter engine. Ran Best with 50/50 mix 98pump (your 93) and Av Gas. The motor felt slightly less responsive with straight Av Gas probably because it's a slower burning fuel.
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
Re: AV GAS
[Re: Challenger 1]
#1798192
04/08/15 01:12 AM
04/08/15 01:12 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I am calling BS on that, if you look at the piston velocities of a Pratt 4360, its equivalent to a SBC at 8000+ rpms. Its not about RPM's it about piston speed.....and at 4500 foot above sea level altitude, our regular gas is only 85 octane...oh and 130-145 octane avgas burns slower than 100 low lead. Your continental or Lycoming engine with a 5" stroke has a lot of velocity and is running at 85% power for hours on end, not something that a car engine typically does. Tim Aviation gas is formulated for low rpm engines at higher altitudes and does not have the BTUs race gas can produce. It sure is better than pump 93 octane that's for sure. It has very different specific gravity also that must be accounted for when tuning. [url=http://www.automotiveu.com/racevsav.htm][/url] Anyone know what this is? I'm turning 2300 rpm and it's almost redlined on 100LL! http://i21.photobucket.com/albums/b260/challenger19711/After%2012-8-14/IMG_52541.jpg
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
Re: AV GAS
[Re: rowin4]
#1798195
04/08/15 01:14 AM
04/08/15 01:14 AM
astjp2
Utah and Alaska
So do you guy's know someone at the airport? the air ports I've been to have the area all fenced in and you have to go through the building , then through a locked door. If you don't have a plane, you don't get passed that door. Bring some cans and tell them you want to buy some gas, the fuel sellers at the airport need to sell fuel to pay their insurance...Tim
Re: AV GAS
[Re: Thumperdart]
#1798208
04/08/15 01:26 AM
04/08/15 01:26 AM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
I've been using LL forever.
30% Av to 87 Octane has been working perfect for me.
Why am I using 87 to blend with LL instead of 91? I don't trust that Premium at the pumps is fresh or really premium at all when you hear about the little stories told from guys at the refineries and Truckers that haul it, so I don't bother with it.
Mo' Farts
Moderated by "tbagger".
Re: AV GAS
[Re: Thumperdart]
#1798221
04/08/15 01:37 AM
04/08/15 01:37 AM
Posts: 13,189 aZLiViN
J_BODY
aZLiViN
Should be in Vegas next month and don't want to mess with E 85 so figured I'd try some. The sell E85 at the Rebel stations in Vegas. Tony (70aarcuda) has three race cars running on it. Al might even have a 4500 E85 carb he might sell..... just a thought.
Re: AV GAS
[Re: J_BODY]
#1798283
04/08/15 02:52 AM
04/08/15 02:52 AM
Thumperdart
State of confusion
No desire to run E 85 at this point or I would build my own carb but who knows down the road.
