Check your facts first before getting all snarky. This cam is two generations old Hughes. The numbering convention is so easy it hurts...HE0914 is 209/214 @ 50 lift on a 112 LSA, ground 4 degrees advanced.
Lift is something like 0.455/0.480 with a 1.5 rocker.
The information is available on Hughes' website if you care to dig it out.
This would be a very good cam for a C-body or a pickup truck running highway gears. As a matter of fact I just might want it. Keep in mind that better flowing heads do not need big durations to make power.
R.
