How much horsepower will 1/4 I.D fuel line support. #1797048
04/05/15 11:56 PM
04/05/15 11:56 PM
western Il.
DRBNSB Offline OP
DRBNSB  Offline OP
western Il.
i have 1/4 I.D. Fuel lines on my dart and am adding a 150 shot of nitrous do I need to upgrade my fuel lines from tank to fuel pump? Mild built 360 with a 750 cfm carb and air gap intake. How much horsepower will my fuel lines support?
Re: How much horsepower will 1/4 I.D fuel line support. [Re: DRBNSB] #1797049
04/06/15 12:12 AM
04/06/15 12:12 AM
N
NITROUSN Online content
NITROUSN  Online Content
N
Zero. You need to do some more homework.
Re: How much horsepower will 1/4 I.D fuel line support. [Re: NITROUSN] #1797050
04/06/15 12:20 AM
04/06/15 12:20 AM
western Il.
DRBNSB Offline OP
DRBNSB  Offline OP
western Il.
It obviously supports some horsepower it's factory type replacement and I have had it on my car for four years now. Do I need to upgrade is my question? Asking questions on here is doing homework ... I thought?
Re: How much horsepower will 1/4 I.D fuel line support. [Re: NITROUSN] #1797051
04/06/15 12:32 AM
04/06/15 12:32 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Hoping its a wet kit, but there's no way I'd rely on that size with a decent displacement small block and nitrous. A lack of fuel when on spray will scatter that engine faster than just about anything else.
Fuel line is not where you should save money. You will be close to the threshold of "not enough" when on the button, and the consequences will be detrimental if you cross that line.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: How much horsepower will 1/4 I.D fuel line support. [Re: DRBNSB] #1797052
04/06/15 12:33 AM
04/06/15 12:33 AM
AndyF Online content
AndyF  Online Content
Depends on your fuel pump. If you have a good pump in the rear of the car you can push a lot of fuel thru a 1/4 line. If you have a mechanical pump on the engine that is pulling fuel thru the line then you'll be limited.
Re: How much horsepower will 1/4 I.D fuel line support. [Re: AndyF] #1797053
04/06/15 12:39 AM
04/06/15 12:39 AM
western Il.
DRBNSB Offline OP
DRBNSB  Offline OP
western Il.
Thanks guys I do have a Holley black pump but it sounds like I better upgrade my fuel line. Thanks again.
Re: How much horsepower will 1/4 I.D fuel line support. [Re: DRBNSB] #1797054
04/06/15 12:49 AM
04/06/15 12:49 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Notice he said 1/4" ID for his tubing, and tubing is named by the OD, so he has the same 5/16 line that 98% of factory musclecars had. Not exactly a zero-power setup, as someone has suggested...
Re: How much horsepower will 1/4 I.D fuel line support. [Re: Fury Fan] #1797055
04/06/15 12:56 AM
04/06/15 12:56 AM
western Il.
DRBNSB Offline OP
DRBNSB  Offline OP
western Il.
Sorry it is 5/16 o.d and 1/4 i.d I didn't know what dimension was needed
Re: How much horsepower will 1/4 I.D fuel line support. [Re: DRBNSB] #1797056
04/06/15 02:36 AM
04/06/15 02:36 AM
IN
ahy Offline
ahy  Offline
IN
The suction side of the pump is most important so the pump is well fed and does not cavitate at higher flows rates.
The factory upgraded to 3/8" for Hemi's... basically north of 400 HP. I would suggest 3/8" minimum from the fuel tank to pump (including pickup) and 3/8" after that with the NOS.
Re: How much horsepower will 1/4 I.D fuel line support. [Re: ahy] #1797057
04/06/15 12:47 PM
04/06/15 12:47 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
3/8" OD line/sender from the tank to the pump inlet and 5/16" OD from outlet to the carb will be more than enough for what a 360 (even on the juice) is going to need.
If a 426 HEMI can sing with this, than he should be fine.
