Steeringcolumn Broadcastsheet codes.. #1796254
04/04/15 01:07 PM
04/04/15 01:07 PM
Sweden
71redcuda Offline OP
Sweden
What does the difference between steering column codes on broadcast sheets like 215x97000 255x97000 255x970005 mean?
Re: Steeringcolumn Broadcastsheet codes.. [Re: 71redcuda] #1796255
04/04/15 03:46 PM
04/04/15 03:46 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Depending on the application, the steering column code could indicate:
Colum automatic,
Column manual,
Console automatic,
Floor shift, manual
tilt/telescopic,
with or without speed control
or other things that could be related to or associated with options or applications of that particular column.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
