Re: 383 Exhuast leak problem [Re: dodger1] #179613
01/01/09 10:23 AM
01/01/09 10:23 AM
MD
floyd Offline
floyd  Offline
MD
I'll second the recommendation for remflex. I had the same problem with my 340 driver. The remflex gasket was an easy fix. Just be careful not to over tighten (DAMHIK).
http://catalog.remflex.com/
Re: 383 Exhuast leak problem [Re: bboogieart] #179614
01/01/09 10:29 AM
01/01/09 10:29 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I don't want to anger you experts,
I am just saying what I know.
(Claims) Please.
If it is a flat exhaust flange it had a gasket.I don't get into debates much but I'll argue with you till the sun sets on this one.The second car I ever took the exhaust pipes off was a 54 Dodge Royal Pace Car convert with a 241 Hemi.It had gaskets fifty four years ago and so did the 50 Plymouth flathead six which was before that.And,if you want to see a parts page as above from a 1957 parts book showing gaskets,let me know.
Re: 383 Exhuast leak problem [Re: 62maxwgn] #179615
01/01/09 11:35 AM
01/01/09 11:35 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
I agree!!!!!!!!
Re: 383 Exhuast leak problem [Re: MO_PA] #179616
01/01/09 02:40 PM
01/01/09 02:40 PM
wisconsin
dodger1 Offline OP
dodger1  Offline OP
wisconsin
Thanks for all the great info ,I know for sure theres 3/8 bolts in it and Well make sure the mating surfaces are flush,
Re: 383 Exhuast leak problem [Re: dodger1] #179617
01/01/09 03:12 PM
01/01/09 03:12 PM
ky.
K
kenworth_goose Offline
K
ky.
I had the same problem on my 77 bigblock truck. Kept burning the gaskets out. It was way to lean. Swapped out the carb for a fatter one and no more burned gaskets.
Re: 383 Exhuast leak problem [Re: dodger1] #179618
01/01/09 03:17 PM
01/01/09 03:17 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
One thing you can try to help out, once youve got it bolted up, take a torch and heat the pipe near the manifold. There is usually a bend hear the flange, try and heat at that bend. (assuming you have acess to a torch)
If there is some sort of stress in the pipe, the heating will take the stress out. youll actually see small parts of the pipe metal flake off as the pipe "un-stressess" Many times while working at a Car-X we would heat certain new pipes to relieve stress. Aftermarket pipes dont always fit correctly. Some would be stressed so much, they would crack off in a few thousand miles.
Re: 383 Exhuast leak problem [Re: NTOLERANCE] #179619
01/01/09 03:18 PM
01/01/09 03:18 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
I didnt see if you posted which side was blowing out, but I will guess its the drivers side.
