1992 and 1996 Dana 60 internals #1795974
04/03/15 09:53 PM
04/03/15 09:53 PM
Round Lake Beach, Illinoisy
Rhinodart Offline OP
Rhinotruck
Rhinotruck
A carrier bearing came apart in my 1996 Ram 2500 with a Dana 60 and I have a 1992 Ram 2500 with a Dana 60 laying around for parts. Are there any parts from the 92 that will interchange with the 96? I will need to replace the carrier assembly, ring gear, and pinion. Trying to keep it on the cheap as the 96 is just a beater.
JB Rhinehart, Realist
A-Body's RULE!
Re: 1992 and 1996 Dana 60 internals [Re: Rhinodart] #1795975
04/03/15 11:22 PM
04/03/15 11:22 PM
Wi
Scat Offline
Scat  Offline
Wi
as long as it have the same tone ring and teeth for the ABS but other then that its good to go. even if it doesnt have that and done care about ABS still would work
73 Duster 340 a518 6pack
Re: 1992 and 1996 Dana 60 internals [Re: Rhinodart] #1795976
04/04/15 12:21 PM
04/04/15 12:21 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Double check your 1992 model to make sure it is not the near identical Dana 61 used for ratios less than 3.54
Re: 1992 and 1996 Dana 60 internals [Re: 360view] #1795977
04/04/15 12:33 PM
04/04/15 12:33 PM
Rhinotruck
Rhinotruck
The donor 92 was a Cummins diesel truck that was rolled, so I am sure it would only have a 3.54 or 4.10. How can you tell the difference in a 60 and 61?
A-Body's RULE!
Re: 1992 and 1996 Dana 60 internals [Re: Rhinodart] #1795978
04/04/15 01:37 PM
04/04/15 01:37 PM
Guitar Jones Offline
Only the early Cummins trucks with the 727 had the 61 in it. Check your axle splines though just to be sure.
Re: 1992 and 1996 Dana 60 internals [Re: Rhinodart] #1795979
04/05/15 04:42 PM
04/05/15 04:42 PM
Wi
Scat Offline
Scat  Offline
Wi
92 cummins would have a dana 70 rear
