Re: Questions for paint guys..
[Re: ademon]
#1794968
04/02/15 04:37 PM
04/02/15 04:37 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
The SEM trim black in quart/gallon form needs to be reduced with their reducer 1:1. I would start with SEM's gun recommendations, and you may need to tweak from there. Test on some paper or scrap before attempting on the vehicle. Holding the gun far away may end up getting you some slight texture. You will definitely be faster to R&R the hood. Less chance of getting overspray on the car, because even masked off you will find some somewhere...paint manages to get to the most crazy places. For materials any paint shop should have paper, tape and fine line tape for the edges. Home depot stuff won't do the job for this one.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: ademon]
#1794971
04/04/15 12:21 AM
04/04/15 12:21 AM
herkamer
Lakewood, Colorado
If it was me, I would prep and tape off the outlines and detail on both, then remove the hood. Tape off the cowl with 18" paper over some plastic sheeting covering everything else. You are shooting such a small area, the overspray will be minimal. That also gives you a place to make sure the hood goes back as it came off. Your back will thank you as well, because if you want you can shoot the hood vertical.
