A727 transmission line fittings #1794190
04/01/15 12:40 PM
04/01/15 12:40 PM
South-Central (Sebring), FL
Commando1 Offline OP
Is it an...
-AN4 or an -AN6 to 1/8 NPT Male?
Thank you.
Re: A727 transmission line fittings [Re: Commando1] #1794191
04/01/15 12:42 PM
04/01/15 12:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
AN6 to 1/8 pipe... you can drill the fitting out some
to help the flow.. dont go crazy
EDIT
its AN6 on the 727... the 518 is AN6
Stock line is 5/16 on the 727 and 3/8
line on the 518 trans... I had to think
what I put on the race car but I am sure
its AN6... I went 3/8 hard line on the 518
since its a street rod
Re: A727 transmission line fittings [Re: Commando1] #1794192
04/01/15 12:44 PM
04/01/15 12:44 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I used -4 on mine.
On second thought perhaps I did go -6. Factory was 5/16", correct? I was thinking it was 1/4" OEM. Senility....
Kevin
Re: A727 transmission line fittings [Re: Commando1] #1794193
04/01/15 01:09 PM
04/01/15 01:09 PM
an8sec70cuda Offline
I use -6.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: A727 transmission line fittings [Re: Commando1] #1794194
04/01/15 01:34 PM
04/01/15 01:34 PM
-6 it is, then. Thank you.
Re: A727 transmission line fittings [Re: Commando1] #1794195
04/01/15 06:03 PM
04/01/15 06:03 PM
NC
440Jim Offline
440Jim  Offline
NC
On my race car with a 727, I have 3/8 steel lines that are terminated with about 18" of AN-4 braided hose to the transmission. I did drill out the ID of the AN-4 to 1/8NPT fittings on the trans since the AN-4 fitting ID was smaller than I liked.
The AN-4 in short lengths works fine, but you may prefer AN-6 if you use braided line all the way to the cooler and back.
Re: A727 transmission line fittings [Re: Commando1] #1794196
04/02/15 12:31 AM
04/02/15 12:31 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
The factory fittings are 1/8" npt to 5/16" flare, it would be AN5 if such a thing exists. Hydraulic hose places have the fittings but not in pretty anodized aluminum, just brass or steel. Of course you could change the fittings to 3/8" ones.
Is it an...
Thank you.
Re: A727 transmission line fittings [Re: @#$%&*!] #1794197
04/02/15 02:45 PM
04/02/15 02:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
AN 5 does exist but it's not too common.
