All,
On my 1970 Duster with a 340, I have had some issues with hard starting over the past two years. Last year it was cured by installing a new cap and rotor and a new set of plugs. It seemed to deteriorate again - and the plugs look fine. Engine runs great once it starts, clean and smooth.
So today, I pull off my 8 month old distributor cap with about 1k miles on it and find this:
It looks pretty messed up to me. What's causing this? Do I have a rotor phasing problem? The distributor is a stock mopar unit curved to run 22 up front and 35 total. Cap and rotor is Accel, and I am running the FBO aluminum white box and coil. Coil gets full battery voltage. Plugs are autolite 3924.
I'm just curious as to what's causing this. This problem may hasten my EFI/coil near plug conversion depending on the root cause.
Thanks for any help.
