Un ID'd firewall hole, 70 Bee #179280
12/30/08 11:24 PM
12/30/08 11:24 PM
Kingsburg Calif.
Quikshft Offline OP
Quikshft  Offline OP
Kingsburg Calif.
There's a fair sized hole right next to (bottom left of) the regulator bracket. I'm sure it's a factory hole because the insulation pad on the cabin side is relieved for it, what goes in that hole?
Re: Un ID'd firewall hole, 70 Bee [Re: Quikshft] #179281
12/30/08 11:37 PM
12/30/08 11:37 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
,not sure on the bee,maybe a/c related ,you need some nice DOUG'S cerimic coated headers in there .looks sweet
Re: Un ID'd firewall hole, 70 Bee [Re: Quikshft] #179282
12/30/08 11:58 PM
12/30/08 11:58 PM
Sacramento,California
JRepucci Offline
JRepucci  Offline
N96 cable?
Re: Un ID'd firewall hole, 70 Bee [Re: Quikshft] #179283
12/31/08 12:06 AM
12/31/08 12:06 AM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
looks like it needs a groumet and a cable is it n-96 car
MOPAR OR NO CAR
Re: Un ID'd firewall hole, 70 Bee [Re: hemigod426] #179284
12/31/08 12:17 AM
12/31/08 12:17 AM
Lansing, MI
70gtx440dana Online content
70gtx440dana  Online Content
Lansing, MI
That is where my vacumm hoses for my 70 Road Runner air grabber come out. Most likely for your cable on your N96.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Un ID'd firewall hole, 70 Bee [Re: 70gtx440dana] #179285
12/31/08 12:20 AM
12/31/08 12:20 AM
Lansing, MI
Lansing, MI
If your car was built at the LA plant that location is likely for the N96. St. Louis and Lynch Road may have used another location I believe.
Re: Un ID'd firewall hole, 70 Bee [Re: hemigod426] #179286
12/31/08 12:37 AM
12/31/08 12:37 AM
Kingsburg Calif.
Quikshft Offline OP
Quikshft  Offline OP
Kingsburg Calif.
Yes it's N96 and built in St Louis. Below is a shot from the inside, aiming the camera thru the hole the radio sits in. You can see how nicely relieved the insulation pad is for 'something' to go thru that hole. I'd be disappointed at this time to find out it's not for something I need.
Re: Un ID'd firewall hole, 70 Bee [Re: Quikshft] #179287
12/31/08 01:09 AM
12/31/08 01:09 AM
Detroit
Kidsixpack Offline
Kidsixpack  Offline
Detroit
Jeff
That's my ram air cable as far as I can tell. My ing. box is over to the right of the hole though? The hole looks like it's in the same spot! The pass. side is alwyts the right side of the car.
KID
Re: Un ID'd firewall hole, 70 Bee [Re: Kidsixpack] #179288
12/31/08 01:16 AM
12/31/08 01:16 AM
Kingsburg Calif.
Quikshft Offline OP
Quikshft  Offline OP
Kingsburg Calif.
Got a picture Steve? Where was your car built?
Re: Un ID'd firewall hole, 70 Bee [Re: Quikshft] #179289
12/31/08 01:21 AM
12/31/08 01:21 AM
St. Louis, MO
DodgeMaterial Offline
St. Louis, MO
Yes -That is the N96 Air Grabber cable hole. My 1970 Coronet R/T (Lynch Rd) is in the same location. See attached - hope this helps. Dave
DodgeMaterial - Dave JS29U0B - FK5 - 440-4 Auto WS23V0A - EB5 - 440-6 Auto
Re: Un ID'd firewall hole, 70 Bee [Re: DodgeMaterial] #179290
12/31/08 01:22 AM
12/31/08 01:22 AM
St. Louis, MO
St. Louis, MO
From the inside...
Re: Un ID'd firewall hole, 70 Bee [Re: DodgeMaterial] #179291
12/31/08 01:47 AM
12/31/08 01:47 AM
Detroit
Kidsixpack Offline
Kidsixpack  Offline
Detroit
Built at Lynch Rd.
KID
Re: Un ID'd firewall hole, 70 Bee [Re: Kidsixpack] #179292
12/31/08 01:57 AM
12/31/08 01:57 AM
Detroit
Kidsixpack Offline
Kidsixpack  Offline
Detroit
Close up. I see that I have the additional orange box! Didn't see the black one untill I took this pic..
KID
Re: Un ID'd firewall hole, 70 Bee [Re: DodgeMaterial] #179293
12/31/08 03:56 AM
12/31/08 03:56 AM
Kingsburg Calif.
Quikshft Offline OP
Quikshft  Offline OP
Kingsburg Calif.
Thanks for all the help guys, below is a shot of a friends car which I've been using for reference. I've taken a number of photo's of it but as you can see it does not match mine in this detail and it also is a St Louis car, but I think it was built in August. Looks like the hole is differend depending on where and when built to me. Anyhow, I don't see anywhere else my air cable could come from, where does the cable control mount on the dash? This is an item I have not yet purchased for my car.
