What cylinder pressure on pump gas?
#1792663
03/31/15 04:55 PM
03/31/15 04:55 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
Changing my Hemi over to pump gas. What cylinder pressure can I get away with on 92 pump gas? All aluminum 4.50 bore motor.
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: What cylinder pressure on pump gas?
[Re: 65 Hemi]
#1792664
03/31/15 04:59 PM
03/31/15 04:59 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
[Re: 65 Hemi]
#1792666
03/31/15 05:48 PM
03/31/15 05:48 PM
an8sec70cuda
You're welcome. My 14:1 wedge motor also has 185 psi...definitely not running pump 93 in that one though.
[Re: 65 Hemi]
#1792668
03/31/15 08:15 PM
03/31/15 08:15 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I run 93 octane in my small block and I have 195-201 lb cranking cylinder pressure. 10.9-1 comp, .255/.266 @.050 camshaft with aluminum heads. Distributor locked out at 35 degrees.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: 65 Hemi]
#1792670
04/01/15 01:08 PM
04/01/15 01:08 PM
an8sec70cuda
Yes, it's a little tougher to run that high of cylinder pressure in a wedge.
The wedge had 275 psi before I changed the cam.
[Re: 68LAR]
#1792672
04/01/15 04:18 PM
04/01/15 04:18 PM
Posts: 6,295 U.S.
moparniac
U.S.
I crank at 170, I run 9s on local 93 gas.
Mopar Performance
[Re: moparniac]
#1792673
04/01/15 06:26 PM
04/01/15 06:26 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I have 190s on pump puke.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1792674
04/01/15 08:28 PM
04/01/15 08:28 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
212 psi is a little too high.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: 65 Hemi]
#1792676
04/01/15 08:43 PM
04/01/15 08:43 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
There was a point made in one of the posts on compression and pump gas that the true test is how well it will run when the motor hits the peak torque area where max volumetric efficiency is achieved. With a big cam and high compression the motor will still need the octane to handle the static (not cranking) compression due to ram intake and exhaust tuning.
[Re: 1980volare]
#1792677
04/02/15 10:17 AM
04/02/15 10:17 AM
an8sec70cuda
Cylinder pressure is not directly related to compression ratio. You need to know cam specs, bore, stroke, rod length, static compression, and valve closing angle. other wise you're just guessing.
Just b/c my wedge cranks 185 psi doesn't mean it'll run on 93. It still has the same 14+:1 compression it did before when it cranked 275 psi...the cam is the only difference. The compression ratio still needs to be on the low end (for the most part) to be pump gas friendly.
[Re: 65 Hemi]
#1792678
04/03/15 01:50 PM
04/03/15 01:50 PM
Posts: 1,765 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
360 mopar, 9.8:1 CR, 175 PSI cranking with a Hughes hydraulic flat tappet cam: 238/244 @ 0.050, with nasty/crappy quench on stock heads. I run 93/94 pump gas...pretty aggresive advance curve: 21 idle@900, 35 @2000. No ping.
[Re: Diplomat360]
#1792679
04/03/15 05:22 PM
04/03/15 05:22 PM
Posts: 12,414 Taxes & Virus's R-US, NY
Dragula
360 mopar, 9.8:1 CR, 175 PSI cranking with a Hughes hydraulic flat tappet cam: 238/244 @ 0.050, with nasty/crappy quench on stock heads. I run 93/94 pump gas...pretty aggresive advance curve: 21 [Email]idle@900[/Email], 35 @2000. No ping.
I would advance final timning even more on that one. All my low compression 340's and 360's liked at least 38...
And for the nay sayers, you can run 14:1 on pump gas....Its called water injection and it works really well. If you can tune a carb, you can tune a water injection system. We have guys tired of paying for race fuel and went this route and will never look back.
[Re: 572charger]
#1792681
04/06/15 11:58 AM
04/06/15 11:58 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
With a loose verter you can get away with 185-195 all day long. Go to a manual trans with the same setup and plan on taking about 5-6 degrees out of total timing or it will be ping city.
Mopar to the bone!!!
