Re: Who's ready for race season?
[Re: 68shifter]
#1792500
03/31/15 09:21 PM
03/31/15 09:21 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Both the Jrs are just about ready. Didn't really need to do much to em this winter.
However, for the first time since 2011 it looks like I will be able to get my charger back out. Have a trip to Summit Racing planned for Thurs evening to get the rest of what we need to get everything ready and with any luck I can 3 of the 4 cars out for the spring warm up on the 18th.
[Re: Dragula]
#1792501
03/31/15 09:24 PM
03/31/15 09:24 PM
Posts: 1,165 Central Ohio, USA
Bigbeep
Central Ohio, USA
Not....Bit off more than I could chew, add hernia surgery to that, and I may not make it....at least with none of my junk. I need a hood, coil overs, push rods, convertor, dyno time. The hood is my biggest problem at the moment. Off on short term disability and I have not seen a single dime yet.
Going to have to run my engine builders 69 Hemi Barracuda instead....I like the wheelies it does, so that's a plus....
Those big dumb wheelies are overrated! Sure they are fun, but expensive as well.
New Ron's fuel pump should be here in the next couple of days, drain antifreeze and fill with distilled water, nut and bolt everything underneath, tag truck and trailer, and finish Raceral's tranny for his Satellite when the rest of the parts come in. Getting the bug bad now that its warming up. Beep
[Re: Bigbeep]
#1792503
03/31/15 09:57 PM
03/31/15 09:57 PM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
Just did chassis cert at Milan last Sunday replaced belts and window net, renewed license, oil change/filter and checked lash now i just have to loose some weight.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
