01 4.7 oil pressure gague drops at idle #1792086
03/30/15 10:44 PM
03/30/15 10:44 PM
Laveen, Arizona
GTSDart340 Offline OP
Laveen, Arizona
01 4.7, 170k miles. Today, sitting at a stop light for about 10-20 seconds, hear a ding. Check gagues light was on, oil pressure gauge reading on the "L" line. As soon as I put it in neutral, it popped back up to the first line on the gague. It's done it to me a few times. It was a little low on oil, OK two quarts! even after filling it back up, it's still doing it. The engine makes no funny noises, even when the gague is sitting at the L. Any ideas? Thanks!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 01 4.7 oil pressure gague drops at idle [Re: GTSDart340] #1792087
03/30/15 10:49 PM
03/30/15 10:49 PM
PA
70Duster Offline
70Duster  Offline
PA
If it's easy and cheap, swap out the sending unit. Otherwise hook up a gage and see what the actual pressure is.
Re: 01 4.7 oil pressure gague drops at idle [Re: GTSDart340] #1792088
03/30/15 10:49 PM
03/30/15 10:49 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
My 03 a few times this winter would show 0 oil psi on very cold mornings. I have 221k on it and have heard the oil psi gauge is not really a gauge but a fancy idiot type light/ gauge which explained why in all that mileage the needle is at the exact same spot no matter temp or oil viscosity. If it bothers you I would replace the sending unit.
Re: 01 4.7 oil pressure gague drops at idle [Re: ademon] #1792089
03/30/15 11:33 PM
03/30/15 11:33 PM
IN
ahy Offline
ahy  Offline
IN
An inexpensive AP store mechanical gauge is a low cost diagnostic. 170k is a fair amount of miles also... bearing clearances may be on the high side. Heavier oil may help if pressure is dropping below 10 or 15 psi at hot idle. 15W40 diesel oil or 20W50 car oil may keep it going.
Re: 01 4.7 oil pressure gague drops at idle [Re: ahy] #1792090
03/31/15 12:14 AM
03/31/15 12:14 AM
Laveen, Arizona
Laveen, Arizona
The thing is that it's not a constant thing. It happens when the engine is hot, but I just took it for a drive, got off the freeway, and it didn't do it. Idled through a parking lot, and it did when I stopped.
