Re: Old School Tunnel Ram on a BIG 540+ Inch HEMI
[Re: domingo]
#1791934
03/30/15 08:11 PM
03/30/15 08:11 PM
Posts: 915 Cincinnati OH
Bishop
Cincinnati OH
How about a Magnesium TR???
[Re: AndyF]
#1791939
03/30/15 09:26 PM
03/30/15 09:26 PM
Posts: 9,679 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
I've done some dyno testing with the old Weiand tunnel rams. They don't make much power when compared to a more modern design.
Is that with the regular Tunnel Rams or with the Magnesium Pro Stock tunnel rams? Cause I think they are different???
[Re: Dragula]
#1791943
03/31/15 04:43 AM
03/31/15 04:43 AM
Posts: 6,424 nielsville, minn.
quickd100
nielsville, minn.
How much power do you want? The old Weiand will still make impressive power. I don't have a scanner to post my dyno sheet so I'll just give the highlites. 605 10.4-1, head flow 386@.700. Start of the pull at 3500rpm, 764.3ftlbs and 513.2hp. 4000rpm 600.8hp, 788.2ftlbs. 4818rpm,(peak torque)750.8hp, 818.4ftlbs. 5782rpm, (peak hp) 852.8hp, 774.6ftlbs.Dave
