Correct Wire Routing for 71 Charger w/Hidden Headlights #1791930
03/30/15 07:36 PM
03/30/15 07:36 PM
Upstate New York
archie340 Offline OP
Upstate New York
Could someone tell me if this is the correct routing to the headlight motor. I have three clips and am not exactly sure where they should go.
Re: Correct Wire Routing for 71 Charger w/Hidden Headlights [Re: archie340] #1791931
03/30/15 11:56 PM
03/30/15 11:56 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
I'll have to see if I can find any of the pictures of my former survivor '71 with concealed headlamps.. But, you can surely browse around Johnny's page and maybe find something..
http://www.71superbee.com/
Troy
Houston Mopar Connection Club
Re: Correct Wire Routing for 71 Charger w/Hidden Headlights [Re: hemi68charger] #1791932
04/02/15 02:02 AM
04/02/15 02:02 AM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
Couple pics from a previous 1971 Charger S.E. that I owned. Untouched car with 34,000 original miles on it. I was the second owner. It looks like you need the rubber coated bracket (unless it's there and I can't see it) that uses one of the headlight bucket mounting bolts to hold it on and two of the rubber coated "snap on" clips. This is the only routing for 71 Charger concealed headlight harnesses that I've ever seen. Hope this helps. Eddie
