66 TRuck Engine swap
#1791904
03/30/15 07:16 PM
03/30/15 07:16 PM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
Im not a proficient truck person YET , I have this 66 and the slant six is boring I have a magnum 360 that doesn’t have a home How crazy is the swap ? should I use the existing 4 speed to simplify linkage , etc , ie Hydarulic clutch . Im almost sure there is a different bell housing necessary ? Or should I swap with an 833 ? Don’t ask me why Im considering this , But if its easy , I may try it . Because Stock Sucks as Mike Bonsanti ( HPMIKE ) says Shumaker doesnt show a swap kit only to b / rb .. Any opinions or past experience would be great . Thanks , Andy https://board.moparts.org/ubbthreads/show...e=0&fpart=1
Re: 66 TRuck Engine swap
[Re: sogtx]
#1791905
03/31/15 02:00 AM
03/31/15 02:00 AM
Posts: 10,666 Freeport IL USA
poorboy
Freeport IL USA
Dodge made those trucks with 318s, so a 360 is not a big stretch. Its possible your slant 6 has a small block bell housing on it, where is your starter located? Is it in the typical slant 6 location, or is it below the trans centerline? Below the centerline should be a V8 bell and you should be able to use that on the 360, but you will need to address the flywheel balance issue with the 360 (the slant 6 flywheel probably won't work). There are a few challenges with using a Magnum, depending on what year. The newer motors don't have the same engine mounting brackets that the old A (or Polly as they called it, which would have been the V8 in your 66) & LA motors had, and the slant 6 brackets on the frame will not match up with your motor mount locations. The magnum motors do not have a provision for a mechanical fuel pump, which will have to be addressed. Are you keeping the efi, or switching to carb?
I had a 66 3/4 ton Camper Special with the polly 318, granny gear 4 speed, and a 4:10 sure grip. That truck was a beast, even though it was a 2 wheel drive, you could go about anywhere. It was a great truck until its rotted out body wouldn't pass inspection any more. Gene
[Re: poorboy]
#1791906
03/31/15 07:36 AM
03/31/15 07:36 AM
sogtx
upstate western ny
Thanks for the reply - it gives me some inititiative to research the swap . The thing that kills me is the axles and wheel adaptability Im thinking that will be an expensive part of the project . I think that lowered and modernized , it would be a very intimidating truck.. But looking for ideas .. Ive just only played with 68-71 bbodies.. This is a whole new animal to me ..
[Re: sogtx]
#1791907
03/31/15 08:14 AM
03/31/15 08:14 AM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Sorta like my old truck. '57, 318, granny low 4-spd, 1 ton, 2 wheel drive.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: RodStRace]
#1791911
04/01/15 10:12 PM
04/01/15 10:12 PM
sogtx
upstate western ny
Kev - theres a red wagon been parked outside aLL winter ( appears clean ) A block from my house -- Im makin a new friend this spring .. My stroker 340 will fit nicely in dat...
[Re: dirt]
#1791914
04/03/15 07:45 AM
04/03/15 07:45 AM
sogtx
upstate western ny
Yes - thanks the sweptline forum is the ticket. Lotss of info there .. Tbcontinued.
