70 cuda top of door molding #1791744
03/30/15 04:09 PM
03/30/15 04:09 PM
pawling n.y.
cudachas Offline OP
cudachas  Offline OP
pawling n.y.
When installing the molding for the top of the doors and quarter panel do I slide the plastic clips into the molding and then snap the molding into the holes in the body or do the clips install in the body first and the molding snapped down on to the clips. The molding is notched on the bottom which makes me think the clips get installed on to the molding first but as usual I could be wrong.Thanks, Charlie.
Re: 70 cuda top of door molding [Re: cudachas] #1791745
03/30/15 07:56 PM
03/30/15 07:56 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Put the mld clips on the body first.When installing the mlds be careful not to hit them too hard,they dent easily because they are aluminum.
Re: 70 cuda top of door molding [Re: 5carguy] #1791746
03/30/15 08:01 PM
03/30/15 08:01 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Make sure the is no paint on the clips, they need to be bare plastic or the trim will be hard to side over the clips. Another tip is to slide the moulding on to one side of the clip and just snap the opposite side over the clip. Don't try to go over both side of the clips at one time.
Re: 70 cuda top of door molding [Re: NANKET] #1791747
03/30/15 10:10 PM
03/30/15 10:10 PM
pawling n.y.
cudachas Offline OP
cudachas  Offline OP
pawling n.y.
Thanks for the advice, I will try the short pieces first and see how that works. Thanks again, Charlie.
Re: 70 cuda top of door molding [Re: cudachas] #1791748
03/31/15 09:05 PM
03/31/15 09:05 PM
pawling n.y.
cudachas Offline OP
cudachas  Offline OP
pawling n.y.
Got all 4 pieces on today, Did it just like you guys suggested. Thanks!
