When installing the molding for the top of the doors and quarter panel do I slide the plastic clips into the molding and then snap the molding into the holes in the body or do the clips install in the body first and the molding snapped down on to the clips. The molding is notched on the bottom which makes me think the clips get installed on to the molding first but as usual I could be wrong.Thanks, Charlie.
