Budget 360 build #1791670
03/30/15 11:56 AM
03/30/15 11:56 AM
ohio
bigblockrik Offline OP
ohio
Needing input on what heads for a 360 that I am going to build for a front engine dragster I just got.Would like to put some 12.5 pistons in it what heads on a budget build ? thanks
Re: Budget 360 build [Re: bigblockrik] #1791671
03/30/15 12:52 PM
03/30/15 12:52 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Pretty vague on your budget, but edelbrocks are about the cheapest aluminum small block head out there.
Re: Budget 360 build [Re: bigblockrik] #1791672
03/30/15 01:16 PM
03/30/15 01:16 PM
Q
Quicktree Offline
Quicktree  Offline
Q
how much is your budget?
Re: Budget 360 build [Re: Quicktree] #1791673
03/30/15 01:28 PM
03/30/15 01:28 PM
ohio
ohio
Haven't set a dollar amount.I want the best bang for the buck.Would like a set of aluminum for the weight savings if the price was right.Never had a small block always run bigblocks.
Re: Budget 360 build [Re: bigblockrik] #1791674
03/30/15 01:32 PM
03/30/15 01:32 PM
Q
Quicktree Offline
Quicktree  Offline
Q
i'll send you a pm after work today.
Re: Budget 360 build [Re: Quicktree] #1791675
03/30/15 10:52 PM
03/30/15 10:52 PM
Q
Quicktree Offline
Quicktree  Offline
Q
bump for the guys to give you a few ideas and costs of building a SB.
Re: Budget 360 build [Re: Quicktree] #1791676
03/30/15 11:00 PM
03/30/15 11:00 PM
Canada
Max Weg Offline
Max Weg  Offline
Canada
I used to run a rear engine dragster with a stock 360 short block with W5 heads on Methonol it ran 8.50 at 150 + at about 4500DA. I still have the engine and the injection.
Max Weg
Re: Budget 360 build [Re: Max Weg] #1791677
03/30/15 11:43 PM
03/30/15 11:43 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
id run the edelbrock heads with closed chamber (non 340 chamber)
get them ported use the kb hypereutectic pistons that fit the closed chamber and make sure you have valve clearance. Put in the proper ring gap. run a solid or roller cam. it will make plenty of power and the rail will fly.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Budget 360 build [Re: cheapstreetdustr] #1791678
03/31/15 10:27 AM
03/31/15 10:27 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have shady dell ported edelbrock heads on my 360.
Parts list
Stock crank
Scat rods
KB107 pistons with .039 quench
Reed solid roller(258ish@.050)
Shady dell stage II edelbrocks with 2.05 valves
Victor intake
Erson 1.6 rockers
Holley 830 annular
It has about 175psi of cranking compresion and runs on pump gas with 35* of timing locked out.
In good good air it has been 11.18@120.5 at 3525LBS in my full exhaust full street trim 68 Barracuda.
In that GOOD air it works out to about 500HP.
68 Barracuda Formula S 340
Re: Budget 360 build [Re: Bad340fish] #1791679
03/31/15 02:13 PM
03/31/15 02:13 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I also have Shady dell stage II ported Edelbrocks on my small block along with:
4” Eagle forged crank (410 cubes)
Scat I-beams
Diamond pistons (set up for 10.8:1 compression for pump gas)
Small solid "street" roller (248/254 @0.05 with .576/.582 lift)
Victor intake
750dp (on e85)
727, 8" converter, 4.10 gears, Hoosier DR 275/60/15
3" exhaust w/ Dynomax race bullets
About 3250-3200 lbs (not sure, have not weighed it in years)
In good air it ran 10.5’s @ 125mph, but usually 10.7’s @ 123 in the summer time crappy air.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
