Re: Brake bleeding ???? 's
[Re: reborn73]
#1791509
03/30/15 02:29 AM
03/30/15 02:29 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Do you get fluid at the left front? Or is it like the passenger side?
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Lefty]
#1791511
03/30/15 07:52 PM
03/30/15 07:52 PM
Posts: 1,894 Harriman NY
71GTX471
Harriman NY
I always start out with gravity bleeding @ the master cyl.then r/r l/r r/f & l/f wheels,crack the lines @ the master one @ a time & watch for fluid flow then connect a clear fish tank type hose to the bleeder N place in a container,wait N watch for clear bubble free fluid flow while keeping an eye on the fluid level & repeat @ the other wheels,then pump the brakes,I like to tap on the master/calipers & wheel cyls. to free up any trapped air & then rebleed,it takes time but works great. ![](/ubbthreads/images/graemlins/coool.gif) P.S don't open the bleeders too much just enough to get good fluid flow,if you keep getting air bubbles in the clear hose put a few drops of oil on the bleeder threads air some times gets sucked in past the threads the oil will seal it up.
