zero oil pressure #1791298
03/29/15 05:24 PM
03/29/15 05:24 PM
WV
WV Runner Offline OP
WV
Ok I'm hoping you guys can help me. Over the winter I installed some indy alum heads, I started the car today for the first time, it fired right up, little noise from the valve train, no big deal. Trouble is after a few seconds I usually have oil pressure, I waited a little longer about 15 seconds, no pressure. I have mechanical gauges and it takes about 5 seconds to get pressure every year on the first start, takes time to fill the line to the gauage. today still no oil in the line at all. I'm thinking the oil pump just went out? any ideas, or suggestions? Motor is a 440, no issues at all last year.
Re: zero oil pressure [Re: WV Runner] #1791299
03/29/15 05:35 PM
03/29/15 05:35 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
pop a valve cover and see. did the valve train quiet down, if so I would suspect your gauge or the line clogged over the winter.
Re: zero oil pressure [Re: mikemee1331] #1791300
03/29/15 05:37 PM
03/29/15 05:37 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
pull the dist and have a look, maybe spin the pump with a drill.
Re: zero oil pressure [Re: ademon] #1791301
03/29/15 05:56 PM
03/29/15 05:56 PM
WV
WV
I pulled a valve cover, there is oil. The noise never quieted down it only ran 15sec.
Re: zero oil pressure [Re: ademon] #1791302
03/29/15 06:01 PM
03/29/15 06:01 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
this would be my next step, with the cover off. or pull the coil wire out and crank it while watching for oiling.
Re: zero oil pressure [Re: WV Runner] #1791303
03/29/15 06:03 PM
03/29/15 06:03 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Pull both covers and check for a loose rocker and (bent) pushrod.
If a pushrod is somehow forced out between a lifter and rocker, the cam will knock the lifter up out of it's bore and you'll loose oilpressure.
There will still be a weak flow of oil near the crank but no pressure higher up or at the gauge.
Has happened 2 or 3 times to me over the years.
This, or the oil pump's pressure control valve is hanging open. Same deal, some flow is present, but hardly no pressure.
Re: zero oil pressure [Re: BigBlockMopar] #1791304
03/29/15 06:12 PM
03/29/15 06:12 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Has happened 2 or 3 times with me over the years.
I had forgotten he had changed heads. there might even be a pushrod not put back right.
Re: zero oil pressure [Re: mikemee1331] #1791305
03/29/15 06:34 PM
03/29/15 06:34 PM
WV
WV
ok my bad guys sorry. I was lazy and pulled the drivers side earlier, there was oil, that's the side I put oil in. I had a brain fart. I just pulled the passenger side, bone dry. all the pushrods and rockers are fine.
Re: zero oil pressure [Re: WV Runner] #1791306
03/29/15 06:49 PM
03/29/15 06:49 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
well, that eliminates about 95% of the guess work. can you spin your rotor by hand? try that and work down from there, not much left...
quick edit - now is the time to get #1 cylinder at the top!
Re: zero oil pressure [Re: mikemee1331] #1791307
03/29/15 06:57 PM
03/29/15 06:57 PM
WV
WV
ok I tried turning the rotor by hand, it doesn't turn.
Re: zero oil pressure [Re: WV Runner] #1791308
03/29/15 07:13 PM
03/29/15 07:13 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
well, if it had turned freely your issue might have been as simple as the oil pump drive or bearing. you're gonna have to pull the dizzy either way. get your #1 cylinder up to the top, pull the dizzy and check the oil pump drive. if all looks in order then it's your pump. the only other thing I can think of is the oil holes in the heads and gasket aren't lined up. and that, my friend, would suck! but it is the only change you made.......
Re: zero oil pressure [Re: WV Runner] #1791309
03/29/15 07:32 PM
03/29/15 07:32 PM
If I'm reading this right the oil you saw in the one head was oil that you added thru the valve cover filler neck? So both heads are dry right? I'm thinking drainback on the filter/suction side. You might pull the filter/cover the filter round flange with a baggie & drill prime it CCW. If still no go I'd pull the pump & see if you can dribble some oil into the in/out block holes to try & help it prime & maybe even pull the pump flat cover & add a bit there too. the heads oil with #6 and #8 at TDC. turning till the rotor is at #8 then pulling the dist/intergear & preoiling right there will take care of that one and then moving 3/4 turn CW to get to the TDC slit (#6 compression) will take care of the other head. I forget which is to which bank but you need both oiled. holler how it goes. EDIT when squared away turn the crank slightly CCW to 15 BTDC (#6 compression) and set the magnet dead even with the reluctor tooth and the rotor under the #6 plug wire cap & clocking the inter gear anywhere so the wires are in their OE location is a good plan (iirc #6 is sideways toward pass fender but check on that). some dists have different top rotor to bottom tang clocking to each other (than an OE dist)
Re: zero oil pressure [Re: RapidRobert] #1791310
03/29/15 10:38 PM
03/29/15 10:38 PM
Houston,Tx.
Lee446 Online content
Lee446  Online Content
Houston,Tx.
Don't some of the Indy heads like the SR's use external oil lines from the oil pressure galley to the head?
Re: zero oil pressure [Re: Lee446] #1791311
03/29/15 11:04 PM
03/29/15 11:04 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
It's rattling, gauge shows no pressure, and the top end is dry. Pure and simple it has no oil flow. Pull the distributor and the drive. Is the drive hex sheared? If it's OK then spin the pump with a hex drive and a drill. No pressure? Pull the relief valve, is it stuck? If no pull the pump and inspect. I'll bet by now you will have found the problem.
Doug
Re: zero oil pressure [Re: Lee446] #1791312
03/30/15 03:48 AM
03/30/15 03:48 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Yes, which heads did you install OP?
Re: zero oil pressure [Re: WV Runner] #1791313
03/30/15 10:19 AM
03/30/15 10:19 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
If all the lifters are in place, there should be some pressure as the readings should come from the main galleys. I'd be priming the heck out of it with good drill.
Re: zero oil pressure [Re: buildanother] #1791314
03/30/15 10:30 AM
03/30/15 10:30 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Could be as simple as an air locked oil filter. Find TDC mark rotor position and pull distributor and intermediate shaft. Crack filter open and prime. See if oil floods out of open filter.
Re: zero oil pressure [Re: MoparforLife] #1791315
03/30/15 09:08 PM
03/30/15 09:08 PM
WV
WV
They are Indy 440-sez. I pulled the distributor and the shaft, the shaft looks fine, Its not stripped. I had to order a priming shaft, I should have it tomorrow? I'm gonna prime the hell out of it and see what happens, I will let you guys know.
Re: zero oil pressure [Re: WV Runner] #1791316
03/30/15 09:25 PM
03/30/15 09:25 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
CCW rotation on a B/RB.
Don't be the exception.
Re: zero oil pressure [Re: WV Runner] #1791317
03/30/15 09:44 PM
03/30/15 09:44 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
you are a patient man! I would been rigging up a cutoff screwdriver or something and really making a mess out of things! kudos for doing it the RIGHT way...
