Re: Racing w/dual quad - A NSS [Re: oldiron] #1791226
04/04/15 09:17 PM
04/04/15 09:17 PM
AndyF Offline
AndyF  Offline
I do make a throttle linkage for the dual carb mod man intake so if you go that way I have the linkage kit.
http://arengineering.com/products/mod-man-dual-carb/
Re: Racing w/dual quad - A NSS [Re: AndyF] #1791227
04/04/15 09:52 PM
04/04/15 09:52 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My brother runs two Eddy AFB carbs on his 400/511 eng in his NSS 64 Fury and he also uses the Mod Man intake. He went to it also for hood clearance issue's as he was using an old tunnel-ram but had to run the taller modern 64 Hemi type scoop even with the lowblock. He wanted to go back to the stock height scoop so thats one reason he went with the Mod-Man intake. His 64 weighs about 3600 lbs with him in it and has run a best of 9.96 using this setup but it normaly runs 10.0's to 10.20's. I dont remember all the jet and spring specs he uses but he had a little stumble issue he had to work with but he has them working very good now as he is very happy using them. His line of thought on the Eddy cars is as he says to me.........I like to run the dual Eddy carbs but on a single carb for racing he prefers a Holley. They are working very well for him right now and I can always get more info on his carb specs as I knew them but dont remember them off the top of my head. Ron
Re: Racing w/dual quad - A NSS [Re: GTSDave] #1791228
04/05/15 12:26 AM
04/05/15 12:26 AM
New Hampshire, USA
O
oldiron Offline OP
oldiron  Offline OP
O
New Hampshire, USA
Hi Dave,
Thanks for the info. Sounds like Damon is a good man to talk to. Two 800s?
Ron, thanks to you as well. Its good to have a comparison.
Andy, your website is down at the moment. Will check it out when it comes back
Happy Easter all.
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Racing w/dual quad - A NSS [Re: oldiron] #1791229
04/05/15 01:43 AM
04/05/15 01:43 AM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
Hi Dave,
Happy Easter all.
Yep,
Two 800's. They are heavily modified, as are all of his carbs. He will ask lots of questions. Different mods depending on stick or auto ect... Since we bolted them on, we adjusted the idle twice. Thats it. Never had them back open yet.
Intake is STR-15 Cross Ram modified to run the carbs inline. There are other mods to it as well, but not willing to give those away hehehe.
Happy Easter to you as well!
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: Racing w/dual quad - A NSS [Re: GTSDave] #1791230
04/06/15 12:10 AM
04/06/15 12:10 AM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
I guess I will find out soon how this set up runs.
Probably over carbed with 750's.
