Page 2 of 3 1 2 3
Re: Wilwood vs Aerospace brakes [Re: Ben Holt] #1790713
04/01/15 10:58 AM
04/01/15 10:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The only brakes we sell are Strange. EVER
Ben.. maybe you will know... but isnt the Strange
caliper built by Wilwood but with Strange name on them..
they sure look the same.. I have both
Re: Wilwood vs Aerospace brakes [Re: slantman] #1790714
04/01/15 12:42 PM
04/01/15 12:42 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
The Wilwood calipers seem to be steel. From the pics.
Aerospace calipers are aluminum.
But I know nothing of the wilwood stuff. I have installed quite a few Aerospace calipers.
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: Wilwood vs Aerospace brakes [Re: 1320Dart] #1790715
04/01/15 12:54 PM
04/01/15 12:54 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Wilwood calipers are aluminum.
I had to shave mine slightly to clear a set of wheels.
Re: Wilwood vs Aerospace brakes [Re: GY3] #1790716
04/01/15 02:19 PM
04/01/15 02:19 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
What rotor are you guys running the solid or vented ones. How much weight is saved over the factory stock disc brakes? Thanks.
Re: Wilwood vs Aerospace brakes [Re: WheelsUp73] #1790717
04/01/15 02:50 PM
04/01/15 02:50 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Solid, vented rotors for street duty.
IIRC, 35 lbs. Per corner over drums.
Re: Wilwood vs Aerospace brakes [Re: WheelsUp73] #1790718
04/01/15 02:52 PM
04/01/15 02:52 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
quote [What rotor are you guys running the solid or vented ones. How much weight is saved over the factory stock disc brakes? Thanks.]
I had the big 11.75? cordoba rotors, caliper bracket & calipers. The Strange kit took off 49 lbs The Strange rotor is a non vented one piece hat. Hubs are aluminum and come with timken bearings with races installed. Aluminum caliper brackets & aluminum 4 piston calipers. Mostly race, some street, stops great, car is 3740
Re: Wilwood vs Aerospace brakes [Re: MoParFish] #1790719
04/01/15 04:08 PM
04/01/15 04:08 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Was gonna go with the Wilwood pro street kit for the front and rear of my scamp, but decided against it when I read on another forum that they drah significantly even after shimming the calipers properly...If im going to spend that kind of coin on brakes, I want them to actually be an improvement over what I already have.
I would go to Strange brakes since I hear nothing but good about them, but unfortunately with my car being a true street car I cant chance running non vented rotors on the street.
So I will just keep my stock junk for now
Re: Wilwood vs Aerospace brakes [Re: mshred] #1790720
04/01/15 07:44 PM
04/01/15 07:44 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Something was wrong, then.
After shimming to properly center the caliper on the rotor, mine don't drag at all!
Re: Wilwood vs Aerospace brakes [Re: GY3] #1790721
04/01/15 08:10 PM
04/01/15 08:10 PM
Toronto
mshred Offline
mshred  Offline
Toronto
http://www.yellowbullet.com/forum/showthread.php?t=1074370
This isn't the only thread I saw saying this either
Re: Wilwood vs Aerospace brakes [Re: mshred] #1790722
04/01/15 08:28 PM
04/01/15 08:28 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
This was brought up in a past post. My wildwood fronts were dragging even with new o-rings. I decided to polish 1 piston & discovered there were very fine machine marks on it. I buffed the piston on my compound wheel till the surface was like chrome. That was 5 yrs ago. Wheel still spins with no drag.
Mark Williams [Re: rickraw] #1790723
04/01/15 08:56 PM
04/01/15 08:56 PM
Dyno1 Offline
Dyno1  Offline
Remember, you get what you pay for. Mark Williams brakes are the best buy for your money. I saw a Superstock car go through the catch fence into the pea gravel at the Jegs Sportnationals in Belle Rose after his Wilwoods failed.
Re: Wilwood vs Aerospace brakes [Re: MoParFish] #1790724
04/01/15 08:59 PM
04/01/15 08:59 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I know you didn't mention Strange but just put them in the front of the 64 Polara on 73 A body spindles. Parts were all well packaged and looked great. Install went well. Took 49 lbs off over the big rotors, calipers and caliper brackets. Stops pretty dog gone good. Worked great today in Vegas
I have Strange all the way around on our car, good luck with them and good customer service.
Bill
Re: Wilwood vs Aerospace brakes [Re: slantman] #1790725
04/01/15 09:51 PM
04/01/15 09:51 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Slantman ,
I have fitted Wilwood to a 69 Roadrunner . got them through Jegs , they have dust boots on the pistons for street use and lower maintenance . Customer has them on his 34 Ford . Both stop great , the Roadrunner got drilled and slotted rotors and were a bit noisey for a couple of weeks till bedded in .
I know EBC do pads for the wilwoods in a couple of different compounds , Yellow and Red .
If you have a spare set EBC or QFM here in Aus can put different compounds on the backing plates - got quoted $90 from QFM
I have SSBC on my Satellite - I may have to try a different compound pad - or brake kit - as at 121+ it is taking a bit more to pull up
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Mark Williams [Re: Dyno1] #1790726
04/02/15 02:05 PM
04/02/15 02:05 PM
Ohio, United States
BuckeyeBrawler Offline
Ohio, United States
REALLY Failed how? What part? Maybe poor installation, improper master cylinder bore? Maybe junk brake lines. Nope HAD to be the Wilwoods! Go figure mine have worked fine on all four corners for last eleven years!
Re: Mark Williams [Re: BuckeyeBrawler] #1790727
04/02/15 02:19 PM
04/02/15 02:19 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Re: Mark Williams [Re: GY3] #1790728
04/02/15 03:26 PM
04/02/15 03:26 PM
Southern California
BIG DRAG Offline
BIG DRAG  Offline
Southern California
Question for those running the Willwood street kit. Are you running the steel spacer that goes between the hub and the wheel? I just don't see the need for this thing but their directions are very specific that it MUST be used if the wheel mounting face is larger than the hub mounting facw...
Re: Mark Williams [Re: BIG DRAG] #1790729
04/02/15 03:42 PM
04/02/15 03:42 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mt experience with Wilwoods over the years ahs been they will eventually drag in most cases. IMO if you want the BEST then that's easy Lamb all the way, MW, Strange, Aerospace and Wilwood. But just my .02
Re: Wilwood vs Aerospace brakes [Re: WheelsUp73] #1790730
04/02/15 04:57 PM
04/02/15 04:57 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My Dart has Strange disks on the front with slotted rotors. They were just a touch over 50 pounds lighter than the 73 disk set up I took off.
On the rear I have Wilwoods with the internal parking brake, they've been on for 10 years with no issues and still running the original pads.
Re: Mark Williams [Re: BIG DRAG] #1790731
04/02/15 07:56 PM
04/02/15 07:56 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Hmmm, my Pro Street kit didn't come with that?
Is it to make it hub-centric?
Re: Mark Williams [Re: GY3] #1790732
04/02/15 09:17 PM
04/02/15 09:17 PM
Southern California
BIG DRAG Offline
BIG DRAG  Offline
Southern California
Nope, just like a wheel spacer. Made out of steel with a multi lug pattern. .200 thick... when did you buy your kit? It appears to be the same thing I have.
Page 2 of 3 1 2 3
