Page 3 of 3 1 2 3
Re: Mark Williams [Re: BIG DRAG] #1790733
04/02/15 09:20 PM
04/02/15 09:20 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Nope, just like a wheel spacer. Made out of steel with a multi lug pattern. .200 thick... when did you buy your kit? It appears to be the same thing I have.
As I recall, it was Mancini Racing. It was the kit for drum spindles.
Re: Mark Williams [Re: BIG DRAG] #1790734
04/02/15 09:34 PM
04/02/15 09:34 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Fitted the spacer/shim on the 69 RR , car does have magnum rims .
I guess if it had smooth faced aluminium rim may not be needed
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Page 3 of 3 1 2 3
