The old 440 is tired, and I have been busy.
#1789849
03/28/15 12:50 AM
03/28/15 12:50 AM
Posts: 1,652 Amarillo, Tx
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
It has been about 2 years since I installed a 440/727 in my 84 swb truck. I have learned a lot about having a RB engine in a half ton. Fun! Just plain fun to drive. So like the title says, the 440 is tired. The 727 more so.
My solution: 79 issue Ma Mopar motor home replacement engine that had an estimated by my machinist less than 10,000 miles on it. The 452 heads got a 3 angle valve job and machine ported, and shaved about .010. The block was honed, crank polished as it didn't need bored, and the crank was within spec. The cam is a comp 268xe. I have 1.6 roller rockers to be added after the break in ( they will put the lift at .512) , along with the tunnel ram and 2 600 eddys. I have a 727 that was a working trans at the trans shop getting a full rebuild, and tf2 kit. The torque converter is a 2200 stall.
This should get installed and broken in over Easter weekend!
I am getting really pumped about it!
84 D150 440/727 79 /6 swb D150 1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: The old 440 is tired, and I have been busy.
[Re: old_goat]
#1789853
03/29/15 02:49 PM
03/29/15 02:49 PM
Posts: 197 Milwaukee, WI
moparjimbo
Milwaukee, WI
If it is going in a truck, with a 2200 converter, etc. and sounds like a pretty mild motor that tunnel ram setup is probably going to leave a ton of power on the table especially at the low end... I mean it looks awesome so it has that going for it, but you would probably be a lot happier and make a lot more power and low end with a dual plane and single 4...
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire 1973 Challenger - 572 Indy Hemi 860HP 1975 Trailduster Convertible, 440 1967 Plymouth Fury Police Pursuit 2DR 505 Stroker 2004 Neon SRT4 modded www.milwaukeemopar.com
[Re: moparjimbo]
#1789854
03/29/15 03:10 PM
03/29/15 03:10 PM
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
I'm going to break it in with my current performer rpm and 750cfm carb and stock rockers. The eventual plan is to use 2 to3/to4 hybrid turbos. The pistons are forged trws. I have another tunnel ram base with injector bungs already installed. The carbs will be converted to be throttle bodys only. I am in the process of building a megasquirt controller now, along with a stimulator. I agree the tunnel ram would leave bottom end power on the table with the carbs. I am going to give them a try though, just for grins. The reason for the converter is to help the tturbos spool. Boost should end up being around 12 pounds with the wastegates I have. I have another driver. After I have the mechanicals and turbo efi lined out, the truck is getting torn down completely for chassis rebuild, rewire, paint and interior. Saturday night cruises, rod runs and an occasional trip to the strip will be its purpose.
[Re: dogdays]
#1789856
03/31/15 12:41 AM
03/31/15 12:41 AM
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
https://board.moparts.org/ubbthreads/show...&PHPSESSID=I know some say a tunnel ram wont work well on the street. I read this thread some time ago. I intend to find out for myself. And then put pressure to it!
