slow wiper motor #178928
12/30/08 03:42 PM
12/30/08 03:42 PM
Lake Orion, MI
goldduster318 Offline OP
Lake Orion, MI
The wiper motor in my '70 Duster runs very slowly in both low and high speed ranges. The high speed range is still slower than the low speed range on your average newer vehicle. Is this normal?
I was thinking about taking the wiper motor off of the car and disassembling it, cleaning it, re-greasing it, and installing it once again to see if that would help. Is that a good idea?
Also, if I were to take it apart, what kind of grease should I use?
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: slow wiper motor [Re: goldduster318] #178929
12/30/08 03:51 PM
12/30/08 03:51 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Check your ground first. You have the classic sign of a bad ground. Run a wire from the wiper ground strap to battery neg. If wipers work correct clean the stud, nut and groubd strap onthe wiper motor. Also make sure you have a good body ground.
