Question for Dealer Tech....2006 Ram Hub Recall #178905
12/30/08 03:20 PM
12/30/08 03:20 PM
NC
DCM71cuda Offline OP
NC
I had this recall done on my truck last December [2007]. A few months ago, I started noticing what sounded like alot of tire noise from the front of the truck. Initially thinking it was the tires, I tried rotating, balancing, tire pressure, etc. It turns out it was a problem with the bearing in the left front hub and the local dealer did the repair as a recall repair.
Since the recall work had [supposedly] been done and I still had a problem, is this something that could keep coming back, or does it mean the recall wasn't done properly the first time?
Thanks for any input.
Re: Question for Dealer Tech....2006 Ram Hub Recall [Re: DCM71cuda] #178906
12/30/08 03:49 PM
12/30/08 03:49 PM
moparmandc Offline
moparmandc  Offline
it has been a while since i did one but it depended on date code on the hub weather it was replaced. if it was replaced they may have used an impact to tighten the big hub nut and brunneled the new bearing and is just now rough enough to make noise. i have done a bunch of those and have not had any come back that i know of.
Re: Question for Dealer Tech....2006 Ram Hub Recall [Re: DCM71cuda] #178907
12/31/08 06:06 PM
12/31/08 06:06 PM
NC
NC
Re: Question for Dealer Tech....2006 Ram Hub Recall [Re: DCM71cuda] #178908
12/31/08 07:18 PM
12/31/08 07:18 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Recall G02 was to replace ft hubs due to insufficient lube from the vendor. If the both hubs were replaced I don't think its the same problem. truck built from 11/9/05----4/27/06
