Re: Dyno Testing Discount For Moparts Members
[Re: mopar dave]
#1787930
03/29/15 11:06 PM
03/29/15 11:06 PM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
I agree, but that's not the dyno i'm goin to. I have a shop 15 min. away with an engine dyno as well as a chassis dyno. i'v given up on getting the pump gas 408 into the 9's in a 3300# full interior car. my new program is in the works with reworked heads by Dwayne Welder to start and a full rebuild of the 408 to a 410 13.5-14:1 comp. and a regrind by bullet of the cam again. the best the 408 did was [Email]10.35@130[/Email] in a street trim that could be driven most anywhere. just gonna put it in the 9's and sell the car. cant afford this hobby any longer.
I would save money that it sounds like you don't have, and sell it as a pump gas 10.30's car. Probably worth as much, if not more than as a race gas 9.90 car that needs Full cage, cert, license, etc, etc. and is likely to appeal to a much narrower audience than the pump gas deal would. If you want to go 9's throw a cheap 150 squirt on it. Best of both worlds.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: mopar dave]
#1787931
03/29/15 11:21 PM
03/29/15 11:21 PM
Posts: 9,977 MI, usa
dvw
MI, usa
ok, so if your done in 4 hours would it be $250?
Can you mount an engine on a dyno and do testing in 4 hours? You are very fast. Doug
[Re: dvw]
#1787932
03/30/15 12:27 AM
03/30/15 12:27 AM
Posts: 52,972 Romeo MI
MR_P_BODY
The dyno I deal with you drop off the engine the day before for mounting
[Re: B1Johnny]
#1787936
03/31/15 07:12 AM
03/31/15 07:12 AM
Posts: 1,770 Pa
Wv68charger
Pa
500 to dyno a motor is an awesome deal,i spent 800 plus fuel.it was worth every penny we found out what the motor wanted.spending a day at Best with tuning help for 500 is a deal.after reading some of these posts about money ,that's why we cant get blocks and heads most Mopar guys not all are cheap.
EXACTLY!
[Re: dartdragracer]
#1787938
04/02/15 08:27 PM
04/02/15 08:27 PM
Posts: 970 Farmington Hills, Mich
Chuck@Best_Machine
Chuck,
Brian V. here. If I can get this deal for $500 Vs. $850, I will go ahead with ordering the Logo Valve covers and cover the cost difference. Great looking Pieces and good way to advertise. The attached picture is from Best Machine Facebook Page. I'll give you a call. Thanks, Brian V.
Done Deal
