Re: Removing the shifter plate from an 833 in car
[Re: Stanton]
#1787752
03/25/15 12:14 PM
03/25/15 12:14 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
Part of the problem is electrolysis - the bolts are steel and the plate is aluminum so the bolts are seized to the plate. Heat is the answer ... if you have oxy/acetylene, use a small flame and heat the bolt head. Let it cool a minute or two then it should break loose.
I think I can heat them pretty easily both from inside the car and underneath.
I'm so close to running in this car, that I really don't want to take a step back and pull the transmission.
[Re: SNK-EYZ]
#1787757
03/26/15 12:25 PM
03/26/15 12:25 PM
AlexP
Houston, Tx
It wouldn't suprise me that the Mopar factory used red locktite on those allen head tapered bolts that hold the plate on I have ruin some cheaper allen wrenches trying to remove those bolts in the past Use some heat on the tranny lugs that those bolts go into first and then try loosening them up Let us know what you do
The factory bolts that I saw years ago actually did have a type of loctite of sorts on them They had what can best be described ad a small hole drilled in the side of the threads that had some sort of nylon thread locker in it. I'm sure it was there to help keep the flat socket head bolt from loosening up.
As far as getting it to loosen up what I've had decent luck with is taking a hammer and round punch and smacking the head of the bolt straight in. Essentially shocking it to help break it loose.
Heat and penetrating oil help too.
If all else fails as others have said since you have a new one if you destroy the old one getting it out it's no big deal. The aluminum shifter bracket is softer than the cast iron trans case. Once the bracket is gone the bolts should spin out relatively easy.
The bolts are done for. No chance of using a proper tool to take them out. I tried the 3/8" drive allen wrenches and they just spun. Someone has already tried this sometime in the last 45 years.
So, I compared the parts that came with the new shifter. A similar plate and thin spacer that was very small.
When you stack them side by side, they end up being the same thickness as the one on the car already. Instead of going backwards, I decided to try bolting it all up with the existing plate and see if it lined up.
It did. I was able to get all the rods on and so far, it looks like it will work. I really dodged a bullet, but there is always the chance that something else will be wrong and it will come out anyway.
[Re: AlexP]
#1787758
03/26/15 02:59 PM
03/26/15 02:59 PM
Posts: 10,144 A Red State
SNK-EYZ
A Red State
The 68-70 B-Body Mopar shifter mounting brackets (like I pictured) are designed for the factory Hurst shifter and normally work on all the Hurst shifters. The main reason for replacing them is because the bolt holes to secure the shifter to the bracket get stripped out. If the original one on the trans isn't stripped out you should be fine reusing the original one.
