Gen 111 Hemi oil pump #1787441
03/24/15 06:11 PM
03/24/15 06:11 PM
Denison,Ia.
Cuda367 Offline OP
Cuda367  Offline OP
Denison,Ia.
Just left dealership. 5.7 oil pump around $60.00 6.1 pump $250.00 and 6.4 pump $100,00. Does anybody know what fits what like will a 6.4 pump work on a 6.1? What is the difference between the three?
Re: Gen 111 Hemi oil pump [Re: Cuda367] #1787442
03/24/15 08:34 PM
03/24/15 08:34 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
If building a 5.7 or 6.1, use a 6.1 oil pump. I have heard of a lot of aftermarket pump failures. I am not sure on the 6.4 pump.
[image][/image]
Re: Gen 111 Hemi oil pump [Re: sgcuda] #1787443
03/24/15 08:39 PM
03/24/15 08:39 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Im using a Melling 10342 with 6.1 spring in my 6.1. Ive heard the new 6.1 pumps from the dealer are made by Melling. Used to be able to get a new 6.1 pump for about $95 now they are north of $200.
Mopar to the bone!!!
Re: Gen 111 Hemi oil pump [Re: 72Swinger] #1787444
03/25/15 12:49 AM
03/25/15 12:49 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I've got a Melling in mine for no particular reason. I'm sure it will be fine, just don't use anything less than a 6.1 pump.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Gen 111 Hemi oil pump [Re: AlexP] #1787445
03/25/15 01:07 AM
03/25/15 01:07 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
A 6.1 has squirters. A 5.7 does not. I really didnt like seeing my oil pressure north of 85lbs at WOT when the squirters were plugged. Several times a year you hear about a filter gasket blowing out and a near wrecked car. What makes the 5.7 pump so bad?
Re: Gen 111 Hemi oil pump [Re: sixpackgut] #1787446
03/25/15 01:23 AM
03/25/15 01:23 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Volume.
Plus, the whole oil pressure situation is weird when you have to take into account the MDS system.
I've only ever bought 6.1 pumps and never had an issue.
I've never seen a filter gasket go, but that certainly makes sense.
Re: Gen 111 Hemi oil pump [Re: AlexP] #1787447
03/25/15 02:01 AM
03/25/15 02:01 AM
San Angelo, Texas
Cevidicus Offline
Cevidicus  Offline
San Angelo, Texas
But a stock non-vvt 5.7 oil pump should be good for a stock short block with mds delete and a mild cam, spinning moderate (6,000) rpm, right?
Re: Gen 111 Hemi oil pump [Re: Cevidicus] #1787448
03/25/15 12:31 PM
03/25/15 12:31 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
with the melling pump being around $170, that is a number I can deal with. The 6.1 pump lists for over $320 if a dealer really wanted to stick it to ya
