340 distributor o-ring seal #1787164
03/24/15 01:12 AM
03/24/15 01:12 AM
Houston Texas, USA
markfh52 Offline OP
markfh52  Offline OP
Houston Texas, USA
Looking to replace the o-ring seal on my distributor. Got one from Oreily but it ain't even close. So, where can I get the right one? Any help would be appreciated.
Re: 340 distributor o-ring seal [Re: markfh52] #1787165
03/24/15 02:48 AM
03/24/15 02:48 AM
Call O'reillys & others & you want an 1/8" O ring with an ID ~1&7/8"
Re: 340 distributor o-ring seal [Re: markfh52] #1787166
03/24/15 03:00 AM
03/24/15 03:00 AM
Hopefully you saved the original O ring, if so take it to a local hydraulic shop and have them sell you two or three new ones of the proper size
Re: 340 distributor o-ring seal [Re: markfh52] #1787167
03/24/15 11:06 AM
03/24/15 11:06 AM
P
Paul_Fancsali Offline
P
Do you have a Prestolite dual point that the difference
Re: 340 distributor o-ring seal [Re: Paul_Fancsali] #1787168
03/24/15 11:20 AM
03/24/15 11:20 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
I can send you one. I've got plenty on shelf, we put them on our cam sensor adapters.
drop me a pm or an email.
Jerry
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 340 distributor o-ring seal [Re: Jerry] #1787169
03/24/15 11:46 AM
03/24/15 11:46 AM
Jerry is top notch . Here's what he did for me: spot on machining/reasonable price. ignore the camera distorsion, everything is perfectly symmetrical
Re: 340 distributor o-ring seal [Re: RapidRobert] #1787170
03/24/15 12:20 PM
03/24/15 12:20 PM
Houston Texas, USA
markfh52 Offline OP
markfh52  Offline OP
Houston Texas, USA
Sent you an email Jerry. Thanks.
I have the original but it's hard as a rock and split when I took it off. Trying to get this 340 sealed up as much as possible to get it back on the road after 25 years.
Re: 340 distributor o-ring seal [Re: markfh52] #1787171
03/24/15 12:40 PM
03/24/15 12:40 PM
If you are in a rush you can use a flat gasket under the base (Ma did it both ways/switched at some point in time/not sure why/likely money/ convenience). You want one thin as a C hair as to not raise the dist/increase the tang slop in the tang/intergear interface. twisting the rotor back & forth slightly just not enough to get into the springs will tell you where you are at with that (with the O ring even). A 4 deg arc of play means the timing can vary 8 deg at the crank (spark scatter). Jerry will take care of ya & here's Jerrys spacers (3/16") installed and you can see that a thin gasket under the wide dist base will seal it up excellent
Re: 340 distributor o-ring seal [Re: markfh52] #1787172
03/24/15 10:23 PM
03/24/15 10:23 PM
New Jersey Bada Bing
bremotorsports Offline
Go to my website and punch in 1326836-P in the green search button on the home page. I have what you need.
Bill Rolik
www.billrolikenterprises.com
Re: 340 distributor o-ring seal [Re: bremotorsports] #1816072
05/01/15 02:13 AM
05/01/15 02:13 AM
Houston Texas, USA
markfh52 Offline OP
markfh52  Offline OP
Houston Texas, USA
Okay, family and business things taken care of and now I can get back to the dart so riddle me this. I got the o-ring from Jerry, thanks. I also ordered one from Bill to get the combo for the distributor.
Both o-rings are not the same as the one I have. They are both larger in ID and don't fit snugly on the distributor and they are both smaller in their thickness.
Kinda of confused at this point.
Re: 340 distributor o-ring seal [Re: markfh52] #1816094
05/01/15 03:32 AM
05/01/15 03:32 AM
the metal gasket definitely looks OE. I measured the housing groove at .113" for the top to bottom height and ~.078" for the depth and 2" for the housing OD so I'd say a 1/8" dia O ring with slightly more than 2" OD. EDIT you want it to stretch a bit so maybe slightly less than 2" OD setting loose on your table
Re: 340 distributor o-ring seal [Re: markfh52] #1816213
05/01/15 10:37 AM
05/01/15 10:37 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Your original was round at one time,the current shape is from it conforming to the slot and becoming hard over time.The one Bill R sent is correct.
Re: 340 distributor o-ring seal [Re: 62maxwgn] #1816723
05/01/15 09:35 PM
05/01/15 09:35 PM
Houston Texas, USA
markfh52 Offline OP
markfh52  Offline OP
Houston Texas, USA
Unless the one Bill sent me can grow it isn't going to work on this distributor. Attached photos of the o-ring in place, very sloppy and the measurements of the grove on the distributor.
Re: 340 distributor o-ring seal [Re: markfh52] #1816725
05/01/15 09:37 PM
05/01/15 09:37 PM
Houston Texas, USA
markfh52 Offline OP
markfh52  Offline OP
Houston Texas, USA
These pictures of the two 0-rings. The original having squared to conform over the years and the one Bill sent me.
Re: 340 distributor o-ring seal [Re: markfh52] #1816728
05/01/15 09:43 PM
05/01/15 09:43 PM
For sure that 3/32" one ain't gonna work/its the wrong one. someone locally (for you) oughta have one that would fit.
Re: 340 distributor o-ring seal [Re: markfh52] #1816970
05/02/15 10:26 AM
05/02/15 10:26 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I have the proper O-Ring for that. It's included in all of our SB Intake Gasket Sets and our Accessories Kits.
