3rd gen Hemi leaking coolant from rear of block???!!! #178662
12/30/08 01:42 AM
12/30/08 01:42 AM
So Cal
GoManGo70Bee Offline OP
super street
super street
So Cal
Noticed a small puddle under my 03 Ram so I crawled underneath and I have what appears to be coolant leaking from my bellhousing!! Now this truck has a 4" body lift so I can clearly see the rear of the heads and they seem dry. Is there a freeze plug on the back of the block? Could it be leaking? What could cause that? I know it didnt freeze as I live in So Cal and it does not freeze here. What would you guys do???
Thanks!!!!
70 Superbee 383 4 speed 70 Hurst 300 67 Dart sedan 74 Ramcharger 03 Hemi Ram 1500 4X4
Re: 3rd gen Hemi leaking coolant from rear of block???! [Re: GoManGo70Bee] #178663
12/30/08 01:49 AM
12/30/08 01:49 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Throw some stop-leak at it and go drive it around. If the cam plug started to seep it should be taken care of.
