ACC Boss Hog Converters
#1786348
03/23/15 01:01 AM
03/23/15 01:01 AM
Posts: 628 Denison,Ia.
Cuda367
Denison,Ia.
Looking for input on them.
Re: ACC Boss Hog Converters
[Re: Mopar-Al]
#1786351
03/23/15 02:38 AM
03/23/15 02:38 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I also had one come apart and spread aluminum throughout my transmission. This was behind my 13-second 383. I sent it back and they rebuilt it. It seemed okay after that, and actually performed pretty well behind the 383. But, when I put it behind the 451 and put a heavier dose of torque to it, it ballooned emediately and caused potentially serious issues. I ended up having to pull the motor to address thrust bearing issues. After these two issues, I junked it and opted to to spend the money on a good converter.
Now, I do have another buddy that runs one in his Dart. Less weight and less torque (12.30 car). It seems to be standing up okay in his application.
I'd be leary of using one behind anything that is going to see the drag strip. Street only, 13-14 second type car is where I'd draw the line.
[Re: StealthWedge67]
#1786352
03/23/15 03:52 AM
03/23/15 03:52 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
I blew one up behind my 408 small block in a 93 dakota and a 904 trans. The stator got mad at me and tried to leave, lucky the flexplate and converter case kept it in place. ![](/ubbthreads/images/graemlins/laugh2.gif)
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: J_BODY]
#1786354
03/23/15 11:59 AM
03/23/15 11:59 AM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
I have been running one in my Mustang for several years. (10.40's at 130) I bought it used and it has worked well. Supposed to be a 4000, but it stalls at 4800 in my car. I have no complaints other than the fact it does not have anti-balloon plates. YMMV though.
I will probably be replacing it with one that does have plates since the new motor should make more steam and I have considered throwing a small shot on it just for giggles.
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
[Re: J_BODY]
#1786355
03/23/15 06:07 PM
03/23/15 06:07 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Did a search on "George Reynolds" (GER fame) and it came up with Precision Converters and transmission..... so if you're looking for cheap krap that fails it appears to be still available.
GER ![](/ubbthreads/images/graemlins/laugh2.gif) Pal of mine with a Nova put one in his car. Turned a 13 second ride into a 14 second turd.
[Re: DusterDave]
#1786357
03/23/15 09:51 PM
03/23/15 09:51 PM
Posts: 515 geezer acres rest home
dakotawilly
have a friend who bought a 10 in G.E.R. about 1985 from jegs for 239 bucks and it is still in the car, a big block challenger.11 second car.flashes to 4200 and works well for what it is,must have been the prototype or the only one done right.maybe he should donate it to the smithsonian............
SFI 25.5 depends,no leak,even at 213 mph....
[Re: dakotawilly]
#1786358
03/23/15 10:39 PM
03/23/15 10:39 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
My old Demon started out with a $225.00 GER 3500 convertor ran a best of 7.38 in the 1/8. People was telling me I need to by a good convertor so I paid $600.00 for a Coan Race convertor and it lost over a tenth in the 1/8. Boy was I mad I wasted $600.00.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
