Am I a flat off in installing the torsion bar? #178578
12/29/08 11:17 PM
12/29/08 11:17 PM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
See pic - it just does not appear right. There is no stress on the bar, but the bar is resting on the adjuster. Is this right or am I a "flat" off?
I have the bars installed on the correct side (I think) R on the pass side, L on the driver side.
Re: Am I a flat off in installing the torsion bar? [Re: 6T6Cuda] #178579
12/29/08 11:41 PM
12/29/08 11:41 PM
calif
cupcake Offline
cupcake  Offline
calif
u got the bump stop off upper arm dogg
Re: Am I a flat off in installing the torsion bar? [Re: 6T6Cuda] #178580
12/29/08 11:47 PM
12/29/08 11:47 PM
(R) bar on pass side & is the wheel hanging off the ground
Re: Am I a flat off in installing the torsion bar? [Re: 6T6Cuda] #178581
12/30/08 12:38 AM
12/30/08 12:38 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I think you'll find that there is no way to go "another" flat.
Crank her up.
Re: Am I a flat off in installing the torsion bar? [Re: cupcake] #178582
12/30/08 08:32 AM
12/30/08 08:32 AM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
Yes the bump stops are installed
Re: Am I a flat off in installing the torsion bar? [Re: superwrench] #178583
12/30/08 10:47 AM
12/30/08 10:47 AM
tennessee
P
pushbutton Online content
pushbutton  Online Content
P
tennessee
I install them with the upper bump stop off,supension hanging. Seems to work.
Re: Am I a flat off in installing the torsion bar? [Re: 6T6Cuda] #178584
12/30/08 11:15 AM
12/30/08 11:15 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
it looks right!the adjuster[hex] will adjust about up to the LCA.
Re: Am I a flat off in installing the torsion bar? [Re: blownzoom440] #178585
12/30/08 11:30 AM
12/30/08 11:30 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You need to have the bump stop removed and the adjuster bolt backed off all the way.
Re: Am I a flat off in installing the torsion bar? [Re: stumpy] #178586
12/30/08 01:13 PM
12/30/08 01:13 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
I just went thru this about a month ago, and it looks right to me. Each "flat" represents 60 degrees (360 degrees divided by 6 flats). It doesn't sound like much, but you'll find that if you rotate the "socket" another 60 degrees clockwise, you'll be bottomed out, your adjuster bolt will be all the way in, and you'll have no way to raise the suspension on that side.
Re: Am I a flat off in installing the torsion bar? [Re: Fab64] #178587
12/30/08 02:36 PM
12/30/08 02:36 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We always seperate the upper ball joint,back off the adjuster all the way,push the lower control arm as far down as we can,make sure the adjuster is rotated down also.Then we install the t-bar to the nearest flat ,this gives use some preload before we adjust the adjuster.
Re: Am I a flat off in installing the torsion bar? [Re: B G Racing] #178588
12/30/08 03:03 PM
12/30/08 03:03 PM
moparx Offline
moparx  Offline
somewhat off topic, but can you crank the lower arm hex enough to put enough tension on the bar to be able to get the bar's rate to factory specs, but have the car set low in the front ? ie. a "flat off" ?
