Re: Welding exhaust on a computer controlled car?
[Re: Stanton]
#1785767
03/22/15 05:14 PM
03/22/15 05:14 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Yep, you're being reckless !!
There is a gizmo that can be connected to the battery so it doesn't have to be disconnected since a lot of newer cars have all sorts of things go berserk if the battery is disconnected. If you don't have the gizmo, don't take a chance on screwing up someone's car, disconnect the battery.
Someone had a post in the General Forum months ago regarding a battery replacement in a late model Dodge. I thought the speedometer read an error afterwards, requiring a reflash from the dealer. This sucks. The Finance guy said this car had 8 computers in it as he was pushing the aftermarket warranty. I am in unknown territory on this one.
[Re: Stanton]
#1785771
03/22/15 06:37 PM
03/22/15 06:37 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
The little welding I did over the years as a tech never seemed to hurt anything but I always unhooked the battery. I can tell you that I had a 2008 Durango towed in the shop that would not run and had been hit by lightening as it hit the radio antenna and burnt it half way off. I ended up having to replace every computer on the truck and also every pressure type of sensor like the MAP sensor , AC pressure transducer sensor , trans pressure sensor and any other sensor that measured any type of presure. That lightening took out alot. Other problem was it took out both computers (cluster and TIPM) that held all the info and options on the truck so I had to download all that info from Chrysler by the VIN. Ron
[Re: Stanton]
#1785776
03/22/15 11:49 PM
03/22/15 11:49 PM
Posts: 9,871 MI, usa
dvw
MI, usa
Yeah well you only have to smoke a customer's computer once to realize that spending $20 "just in case" might not have been such a bad idea !!!
If it ever happens I'll let you know. Have you ever damaged one? Doug
[Re: forphorty]
#1785779
03/23/15 12:28 AM
03/23/15 12:28 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I work in a body shop. I weld on modern cars all the time. I don't disconnect the battery either. Maybe I'm being reckless, but I've never had a problem in 20+ years.
Same here I have done LOTS of welding on 07+ Wranglers with the battery hooked up. Up to and including an entire roll cage, no issues.
[Re: Mr T2U]
#1785780
03/23/15 01:30 AM
03/23/15 01:30 AM
Posts: 35 IN
formerratman
IN
Worked as tech for over 30 years, never disconnected the battery. Never had any issues. Doug
also been a auto body tech for over 30 years. never have disconnected anything before welding. burned a few interiors but never had any electrical problems. I always put the ground clamp about 1' away from the welding area.
Exactly.
[Re: Twostick]
#1785781
03/23/15 03:12 AM
03/23/15 03:12 AM
Posts: 6,516 Santa Cruz, California
Lefty
A good idea to disconnect the battery.
The welder ground should be as close to where you are welding as is practical. If you are welding in a muffler, I would have the ground clamp on the pipe I was welding on a foot or 2 away.
Kevin
I do the same - get the ground clamp as near to the weld spot as I can and disconnect the battery. I've never zapped anything but I don't weld on the newer computer infested cars.
