Slow starter still causing issues #1785224
03/21/15 10:49 PM
03/21/15 10:49 PM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
From my first post i finally had some spare time to look at the dart. a 383 bigblock
833 transmission
mini starter
I decided to remove the variable of my wiring harness and wire the starter directly. off the engine it spins freely. I used 4awg wire for both negative and positive. i cleaned the block ground, put a ground from the block to the body, and made a jumper wire for the starter. before installing the starter i tested the battery with the voltmeter and it read 12/12.2 when i installed the starter and grounded it, the voltmeter read 10.0 and the starter was just clicking. any idea or suggestions?
Ryan
Re: Slow starter still causing issues [Re: ryanf] #1785225
03/21/15 11:25 PM
03/21/15 11:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you had the battery load tested?
Re: Slow starter still causing issues [Re: ryanf] #1785226
03/21/15 11:27 PM
03/21/15 11:27 PM
12-12.2 seems a bit low (maybe). Also the bendix gear has to pushed by the solenoid rod into the flywheel teeth pretty much before the main starter is energized. Might be an issue there or a juice problem. Did we try another battery? recent problem? I'd loosen the starter & have a helper work the key as you jiggle/move the starter. Is there an inspection plate if removed will let you see if the teeth are coming all the way forward to mesh & you can take off the main cable & jump the solenoid only to kick it forward & see how it is going (if you can visually see them mesh on a stick, I dont know sticks)
Re: Slow starter still causing issues [Re: RapidRobert] #1785227
03/21/15 11:32 PM
03/21/15 11:32 PM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
i have not had the battery tested but its a new one put on a trickle charger, pulled another from a working car, still the same issue. Everything is new/rebuilt trying to break the engine in.
I removed the inspection plate and when installed the starter gear is meshing with the flywheel.
Re: Slow starter still causing issues [Re: ryanf] #1785228
03/21/15 11:35 PM
03/21/15 11:35 PM
N
NITROUSN Offline
NITROUSN  Offline
N
12.0 to 12.2 is a battery that is very low on charge. Your fully charged battery should be 12.6 or better.
Re: Slow starter still causing issues [Re: NITROUSN] #1785229
03/22/15 12:34 AM
03/22/15 12:34 AM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
i put the battery on the charger and went underneath the car to snap this picture of the starter gear and flywheel.
Re: Slow starter still causing issues [Re: ryanf] #1785230
03/22/15 01:14 AM
03/22/15 01:14 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Your picture shows the solenoid able to pull the drive gear in. All that shows is the starters small wire able to pull enough current to draw it in. Now you need to find out where the big wire or ground is failing. You need to test each with a voltage drop. The simple problem is just about smacking you in the face.
Re: Slow starter still causing issues [Re: NITROUSN] #1785231
03/22/15 01:31 AM
03/22/15 01:31 AM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
that picture is the starter at rest, when power is added it just clicks. i have jumped the small and large starter wires. ground is to the block, to the front sub frame, from the block to the firewall, and to a bumper bolt. please tell me what i am missing.
Re: Slow starter still causing issues [Re: ryanf] #1785232
03/22/15 03:07 AM
03/22/15 03:07 AM
I spaced that you have a mini. I have one & I'll look at it tomorrow (if someone or some tidbit of info doesn't help you before then). On a mini the teeth are normally engaged into the flywheel at rest (like yours is in the pic?) New territory for me
Re: Slow starter still causing issues [Re: RapidRobert] #1785233
03/22/15 10:01 AM
03/22/15 10:01 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
I am probably not looking at the picture right but i'll ask based on what I think I see.
why is the starter gear engaged with the flywheel 'at rest'?
Re: Slow starter still causing issues [Re: mikemee1331] #1785234
03/22/15 10:06 AM
03/22/15 10:06 AM
USA
540DUSTER Offline
540DUSTER  Offline
USA
I was thinking the same thing mikemee
Re: Slow starter still causing issues [Re: mikemee1331] #1785235
03/22/15 10:20 AM
03/22/15 10:20 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Me to. Is the starter hitting the side of the block like often happens with a mini in a BB? If it is then when you tightened the starter bolts it may have cocked the starter nose towards the flywheel jamming the gears.
Re: Slow starter still causing issues [Re: GomangoCuda] #1785236
03/22/15 10:40 AM
03/22/15 10:40 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
or the wrong starter...
Re: Slow starter still causing issues [Re: mikemee1331] #1785237
03/22/15 12:08 PM
03/22/15 12:08 PM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
so both mini starters have the gears resting in the flywheel. The nose of the starter fits right in the hole of the bellhousing and is flush against the block. so i take it the starter gear should not be resting in the flywheel? could this be a problem with my flywheel?
Re: Slow starter still causing issues [Re: ryanf] #1785238
03/22/15 12:13 PM
03/22/15 12:13 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
this is absolutely the problem the gear is being driven forward to engage the flywheel (as it should) but it is already engaged so it binds. this story would not have ended well for that starter if it had started up!
Re: Slow starter still causing issues [Re: ryanf] #1785239
03/22/15 12:21 PM
03/22/15 12:21 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Are you working on a riding lawn mower?
4 awg is too small.
Starters draw a lot of current, the wire has to be able to carry it.
Don't be the exception.
Re: Slow starter still causing issues [Re: mikemee1331] #1785240
03/22/15 12:58 PM
03/22/15 12:58 PM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
So if this is my problem how do i fix it? as either the starter gear is to long or the flywheel teeth are to close.
Re: Slow starter still causing issues [Re: ryanf] #1785241
03/22/15 01:18 PM
03/22/15 01:18 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
what starter are you using?
Re: Slow starter still causing issues [Re: mikemee1331] #1785242
03/22/15 02:03 PM
03/22/15 02:03 PM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
I am using a mini starter
Re: Slow starter still causing issues [Re: ryanf] #1785243
03/22/15 02:15 PM
03/22/15 02:15 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
my bad, what mini starter? I read in your other post that you ordered a new one from the parts store but what did you order?
