Page 3 of 3 1 2 3
Re: Anyone interested in a 2.5lb battery to start their car [Re: F1Scamp] #1785107
03/24/15 03:55 PM
03/24/15 03:55 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
I run an antigravity 16v race battery, weighs alittle over 4lbs. Did a test to see how many times it would start the car and run it without charging, but I ran out of fuel before I could find out. Started the car and ran it for 3 1/2mins 10x's before I ran out of fuel.. Electric fuel pump, msd, etc. After the 10 times the voltmeter showed 16.7v and it took 25mins to bring it back to full charge. You can get them for around a hundred less than what their online store shows if you have a local dealer. Pretty awesome battery to hide in a factory case...
Do you have a link?
Re: Anyone interested in a 2.5lb battery to start their car [Re: sixpackgut] #1785108
03/24/15 04:12 PM
03/24/15 04:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have no idea Ray..... I'll change styles of battery
when I can buy it local.. that way when mine does
die I can get one anywhere... my battery in the race
car is still going strong.. 9 years racing and now
it sits in the car.. thats 2 years now.. just for kicks
when I was in the trailer today I tested it.. 13.5v..
I feel bad about that battery... its sorta dirty
but otherwise still going ... if the battery in the
Rampage last half as long I'll be happy... I do run
a charging system on all my junk
Re: Anyone interested in a 2.5lb battery to start their car [Re: MR_P_BODY] #1785109
03/24/15 08:32 PM
03/24/15 08:32 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Have one in the race car, one in the tow truck, and one in trailer with an inverter to run the 110 lights, that's three, how many more do you need?
Re: Anyone interested in a 2.5lb battery to start their car [Re: OUTLAWSSAA] #1785110
03/24/15 09:01 PM
03/24/15 09:01 PM
NY
F1Scamp Offline
F1Scamp  Offline
NY
Do you have a link?
http://shop.antigravitybatteries.com/antigravity-batteries-16-volt-vtx12-20/
Their small jump packs are pretty amazing as well. I have started 8 cars in a row without charging.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
Re: Anyone interested in a 2.5lb battery to start their car [Re: F1Scamp] #1785111
03/25/15 12:11 PM
03/25/15 12:11 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I don't want to go through the headache of using a 16V battery. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Anyone interested in a 2.5lb battery to start their car [Re: astjp2] #1785112
03/25/15 01:50 PM
03/25/15 01:50 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
My Daytona went thru about (3) 16 volt turbo starts over years so one day I did a back to back test switching out a charged 16 volts battery for a charged 12 volt battery. The car was running 8.70's at the time and ran exactly the same with both batteries. I have now gone a step further and added a chevy single wire 60 amp alternator and monitor my passes on my RacPak and all is well.
The small tire Duster I just bought came with a 16 volt battery and being its a heads-up type class I will check it out and possibly re-buy a 16 volt charger. These cars have so many critical electronics in them you better not have a voltage drop or it may cost you an engine.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Anyone interested in a 2.5lb battery to start their car [Re: pittsburghracer] #1785113
03/25/15 03:51 PM
03/25/15 03:51 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
I bought this one so I could charge 16 or 12 volt.
http://www.summitracing.com/parts/pwm-1005
One day I will have something cool here.
Re: Anyone interested in a 2.5lb battery to start their car [Re: sdaurity] #1785114
03/25/15 05:56 PM
03/25/15 05:56 PM
PA.
"Little"John
"Little"John
PA.
Yes that's the one I was looking at so I could use it on both cars. I even had a 16 volt alternator at one time but sold it.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Anyone interested in a 2.5lb battery to start their car [Re: pittsburghracer] #1785115
03/25/15 05:59 PM
03/25/15 05:59 PM
PA.
"Little"John
"Little"John
PA.
282 dollars with Pro-Shop discount. I can go out and get an ice creme cone now.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Page 3 of 3 1 2 3
