1970 Hemi Starter #1784878
03/21/15 02:36 PM
03/21/15 02:36 PM
Ohio
RestoreCuda Offline OP
Ohio
Please educate me. The 37 Amp alternator is coded on the build sheet for my Cuda but not the starter. What is the proper part number for a 1970 Hemi 4 speed starter? Also is a 4 speed starter different from a starter for a Hemi automatic? Thanks in advance.
Re: 1970 Hemi Starter [Re: RestoreCuda] #1784879
03/21/15 02:42 PM
03/21/15 02:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
'70 and later Hemi uses the same starter auto or 4-speed...same starter for all engines.
Re: 1970 Hemi Starter [Re: John_Kunkel] #1784880
03/22/15 07:33 PM
03/22/15 07:33 PM
Ohio
Ohio
I found a part number. Can anyone tell me what it is correct for? 2875560. Thanks.
Re: 1970 Hemi Starter [Re: RestoreCuda] #1784881
03/23/15 12:31 PM
03/23/15 12:31 PM
70RT Offline
70RT  Offline
This part number would be correct for your 1970 hemi application. Auto and 4-speed used the same starter through at least the 1971 model year. Be careful with the parts counter books. At least with alternators, there are part number differences from what the assembly line actually installed.
Re: 1970 Hemi Starter [Re: RestoreCuda] #1784882
03/23/15 12:51 PM
03/23/15 12:51 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
The alternator should be a 50 Amp one, standard on Hemi's. the 37 amp is used for all other cars, Part number for the 37 amp is 3438 172. I think that the Hemi one should be 3438 173, can anyone confirm this?
The starter, 560 is the same for ALL engine sizes, I actually didn't know that the 560 was also used on Hemi's.
Re: 1970 Hemi Starter [Re: m46rat] #1784883
03/23/15 06:08 PM
03/23/15 06:08 PM
CA
cudino Offline
cudino  Offline
CA
As I know all the Hemi E-bodies got PN 3438176, and will have '76' on the Broadcast Sheet under ALT. I believe the 3438172 is basically the same alternator, except 172 has the single groove pulley (for 440-6 cars) vs. the dual-groove pulley on the 176/Hemi version. I think these were all 37A versions, and while the 172s can be bought the 176 version is darn near impossible to find. As I remember 3438178 is also a dual-pulley, but is the 50A version, for use on cars with A/C.
- Wade
Re: 1970 Hemi Starter [Re: cudino] #1784884
03/23/15 08:29 PM
03/23/15 08:29 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
2875560 is the correct starter but I have found there are two different barrel lengths..if I remember correctly the longer by 3/8" one being the one performance cars got.
Re: 1970 Hemi Starter [Re: mccannix] #1784885
03/23/15 11:12 PM
03/23/15 11:12 PM
Ohio
Ohio
Thanks a lot for the help.
